May 16, 2012, 08:44 |
Grashof Number
prince
Rep Power: 15 |
I am solving natural circulation flow in closed loop which is assisted by nitrogen injection in hot leg to increase the flow rate of coolant in the loop. Injected nitrogen is separated before the heat sink.
I am not able to decide which parameter Grashof number or Reynolds number will decide whether the flow is laminar or turbulent. Also how can i calculate two-phase grashof number ? I get a correlation to calculated Grashof number for closed loop but it for single phase (Vijyan et al 1992) Thanks |
May 16, 2012, 11:21 |
Erik
Rep Power: 23 |
Calculate both Gr and Re, if either is in the turbulent regime you are turbulent.
May 17, 2012, 05:21 |
prince
Rep Power: 15 |
Thanks for reply..
It is turbulent then.. |
[snappyHexMesh] Number of cells in mesh don't match with size of cellLevel | colinB | OpenFOAM Meshing & Mesh Conversion | 14 | December 12, 2018 09:07 |
[mesh manipulation] Mesh Refinement | Luiz Eduardo Bittencourt Sampaio (Sampaio) | OpenFOAM Meshing & Mesh Conversion | 42 | January 8, 2017 13:55 |
[snappyHexMesh] snappyHexMesh aborting | Tobi | OpenFOAM Meshing & Mesh Conversion | 0 | November 10, 2010 04:23 |
meshing F1 front wing | Steve | FLUENT | 0 | April 17, 2003 13:37 |
Grashof Number | Adrian | Main CFD Forum | 7 | May 1, 2001 18:02 |
