May 11, 2012, 14:07 |
Fluid-solid flow in pipe model...need help..
Oat Mongkhol
Rep Power: 14 |
I have a aproblem to set up the proper model for Fluid-solid Flow in pipe.
I want to simulate the fluid transport ability (density of fluid is less than solid partical), which i will vary flow rate and density to see the proper condition the clean up the solid partical in the pipe.... Please give me the guide line....Thanks in advance |
May 11, 2012, 14:13 |
Oat Mongkhol
Rep Power: 14 |
My model will use volume fraction inlet as Fluid/solid = 80/20...
as the outlet side, when the velocity of the fluid is not sufficient, some of the solid partical should stay in the bottum of the pipe as stationary layer while some of the solid partical will dispered in the fluid phase.....any ideas....to help Thanks |
No results for solid domain | Gary Holland | CFX | 10 | March 13, 2009 04:30 |
gas solid pipe flow | tahar | Phoenics | 6 | November 3, 2003 13:03 |
Turbulence model for Transient Pipe Flow Modeling | Brian | FLUENT | 0 | June 7, 2002 13:15 |
CFX4.3 -build analysis form | Chie Min | CFX | 5 | July 13, 2001 00:19 |
Turbulent non-Newtonian fluid flow using k-w model | Athar Zaidi | CFX | 1 | February 1, 2000 16:46 |
