acoustics and low mach number
Old   October 30, 2005, 06:19
Default Re: further thoughts: acoustics and low mach numbe
  #41
andy
> What would you suggest for appropriate boundary-conditions where wave
: phenomena show themselves?
Perhaps the simplest reasonable ones are those of Thompson (J. Comp. Phys. late 80s) but the subject has received a lot of attention during the 90s as CAA and general purpose compressible flow developed.
> Do commercial solvers allow such boundary-conditions?
I do not have direct experience but several of the fruitful areas like unsteady flow in compressor/turbine blading will require it and so I expect the answer is yes.
Old   November 3, 2005, 05:46
  #42
George
Hello again! I overcame this problem that I had and everything is going perfectly. Thank you very much for your advice. I implemented my code for moving walls also and for pressure boundary conditions and it converges and the results are fine (without any scock-like regions). The problem was at the differencing scheme that I am using (hybrid).I did not include the temp div(u) in the Ap coefficient.What a silly thing to do... Nevermind...
Old   November 3, 2005, 07:05
  #43
diaw
Well done... Good luck with your future research...
diaw...
WAVE Ricardo Software CED Main CFD Forum 45 May 31, 2019 05:24
Noise and Turbulence Matthias Main CFD Forum 9 May 11, 2001 05:38
