October 23, 2005, 07:16 |
m.peric code
Hi every body I'm using (M.PERIC 2D FVM COLLOCATED GRID,CODE) In this code i have to implement constant flux B.C,as source terms e.g qs=su+sp*Tp (Tp temperature of considered node) how can i do this?
sorry for intrupt |
October 23, 2005, 08:22 |
Re: m.peric code
Can you refer to book by Fletcher, Volume 2, 2nd ed., page 340-341, It is for velocity b.c. case discussed, but it would stiil be similar, and I think you will set, the heat flux eqn as , ie -q''/k=dT/dx=1, and in similar fashion you discretized the main equation you discretize the dT/dx accordingly and get your new b.c. equation. When you dimensionalize it you use the right scaling to get realistic q",
... but if only it helps, and I didnt see Perics code for a while too, good luck |
September 14, 2012, 03:05 |
Rep Power: 14 |
Hello everyone
I have some challenge in using the peric code For example consider 2DGL, when I generate the gird for the geometry, what's the next step??? Should I use the Caffa.f or user.f ???? I read the read me file, but I don't understand. Thanks for your help. |
The FOAM Documentation Project - SHUT-DOWN | holger_marschall | OpenFOAM | 242 | March 7, 2013 13:30 |
How to make code run in parallel? | cwang5 | OpenFOAM Programming & Development | 1 | May 30, 2011 05:47 |
Open Source Vs Commercial Software | MechE | OpenFOAM | 28 | May 16, 2011 12:02 |
Small 3-D code | Zdravko Stojanovic | Main CFD Forum | 2 | July 19, 2010 11:11 |
public CFD Code development | Heinz Wilkening | Main CFD Forum | 38 | March 5, 1999 12:44 |
