isentropic flow
Old   October 20, 2005, 11:32
Default isentropic flow
Nashat
Are there any benchmarks for compressible, isentropic flows in 2D. If someone can point me to an analytical solution that would be great.
Thanks a lot.
Old   October 20, 2005, 12:39
Default Re: isentropic flow
ag
The most basic would be flow over a wedge, producing an oblique shock. You may also want to look at Ringleb flow.
Old   October 20, 2005, 15:01
Nashat
Thanks ag.
Old   October 21, 2005, 08:59
Anton Lyaskin
Are you sure that flow tih an oblique shock will be really ISENTROPIC?
Old   October 21, 2005, 10:00
ag
The shock will not be isentropic. I assumed he was looking for sample problems that are solutions to the Euler equations. Apologies for my misread.
Old   October 22, 2005, 10:46
ganesh
Dear Nashat,
One of the starting points could be to try the flow in a nozzle, say converging or converging-diverging. If you maintain the proper pressure ratio, you could get an isentropic flow. You could also try varying the pressure ratios so that you have shocks. This would help if you are looking for Euler cases. There are other problems like the circular advection problem, wherin streamlines are circular and you could get the details easily by a search.
Hope this helps
Regards, Ganesh
Old   October 23, 2005, 18:37
Nashat
Thanks Ganesh. Nashat
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 06:21
Flow meter Design CD adapco Group Marketing Siemens 3 June 21, 2011 09:33
What is the difference between liquid reactive flow and gas reactive flow? James Main CFD Forum 6 May 15, 2009 13:14
reversed flow at velocity inlet / mass flow inlet ib FLUENT 1 March 26, 2007 14:11
transform navier-stokes eq. to euler-eq. pxyz Main CFD Forum 37 July 7, 2006 09:42
