October 14, 2005, 00:29 |
C# vs other programming languages
Hi Everyone,
Do you think C# can prove a better alternative than C++ or C for CFD? Moreover, is Matlab good enough to handle CFD? regards Metal |
October 18, 2005, 03:28 |
Re: C# vs other programming languages
C and C++ are well tested in CFD field. C# is much like Java than C++. MATLAB can be used for CFD and provides interfacing with C/C++ and FORTRAN. It depends on your problem as you need to build your own NS solver using MATLAB functions. You may need to write your own functions too.
October 18, 2005, 03:48 |
You would have to expand on what better means but it is hard to see any advantages and the disadvantages (platform dependence, speed, lack of existing numerical routines, few CFD people know the language, etc...) look pretty compelling. > Moreover, is Matlab good enough to handle CFD? Using a scripting language like Matlab (or Python, Ruby, etc...) is a well established way to go about researching numerical methods/schemes within CFD programs. It makes parametric changes easy and the generation of subsequent plots and movies. However, apart from the controlling routines, most of the low level number crunching routines are usually written in languages like C or Fortran to avoid the speed penalty of an interpretted language. Matlab effectively provides the packaging. Writing all the statements of a 3D CFD code in the Matlab language would not be wise. |
A book for a beginner wanting to learn programming | frank | Main CFD Forum | 9 | May 12, 2014 23:15 |
OpenFoam programming | prapanj | OpenFOAM | 10 | March 18, 2010 07:23 |
Programming in OpenFOAM | vinu | OpenFOAM | 2 | July 11, 2009 10:16 |
CG/GPU/brook programming language - FLUENT/CFX | Quick | Main CFD Forum | 0 | April 3, 2006 18:32 |
new CFD Programming Forum | Thinker | Main CFD Forum | 14 | November 19, 2002 16:03 |
