Forced Convective Heat Transfer for moving cylinde
Old   October 11, 2005, 07:32
Default Forced Convective Heat Transfer for moving cylinde
I am interested in estimating the convection heat transfer coefficient of a cylinder moving in water. The length of the cynlinder can be taken as L and diameter as D and L/D ~ 2. The cylinder speed may be taken as 15 m/s.
I would be grateful if someone could suggest me an empirical technique/ formulae with theory for estimating the same.
thanx in advance
Old   October 11, 2005, 07:44
Default Re: Forced Convective Heat Transfer for moving cyl
diaw
Set up a simple model with fixed cylinder & moving water (relativitity). You can tackle the heat input in 2 ways:
1. Macro - measure overall water temperature diffeence up & downstream & compute the heat-transfer. Work backwards to calculate the average heat-transfer coefficient.
2. Surface - from the solution, compute the surface temperature gradient & then onto the local & average surface heat-transfer coefficient.
Some packages will even allow the user to collect the surface fluxes.
These can be found in almost any standard college theat-transfer textbook.
"Fundamentals of Heat & Mass Transfer", Incropera & Dewitt, is a good one.
Bejan has a few good books.
diaw...
Old   October 11, 2005, 15:36
Ahmed
Free is always better http://web.mit.edu/lienhard/www/ahtt.html
Old   October 11, 2005, 15:43
Ahmed
Free is always better http://web.mit.edu/lienhard/www/ahtt.html http://www.knovel.com/knovel2/Toc.jsp?BookID=725
Water subcooled boiling Attesz CFX 7 January 5, 2013 04:32
Convective / Conductive Heat Transfer in Hypersonic flows enigma Main CFD Forum 2 November 1, 2009 23:53
How can I increase Heat Transfer at Domain Interf? B.Simon CFX 3 October 28, 2008 19:53
UDF convective heat transfer correlations sarah FLUENT 0 March 29, 2007 10:52
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 16:55
