Increasing resolution of mesh in GAMBIT
Old   October 9, 2005, 18:07
Default Increasing resolution of mesh in GAMBIT
Vidya Raja
Hi, I've meshed a solid imported from ProE into Gambit. I want to increase the resolution of the mesh. Is there any way I can do it? Do I need to use sizing functions? If so, how do I use them and are there any specific criteria that I need to follow?
Thanks, Vidya
Old   October 10, 2005, 04:11
Default Re: Increasing resolution of mesh in GAMBIT
nidro
you want probably refine unstructured mesh. If your solver doesn't allow it, you have to do it making use of sizing functions if want to use gambit. Do not want to discourage you, but you shout outfit with patience. The gambit behaves sometimes, upredictably. There is some kind of heurestics built in gambit, that keeps the user's mind always fresh. Anyway, if your domain is simple cube, you can afford some kind of play around with gambit.
good luck!
mesh missing after export in gambit morteza08 ANSYS Meshing & Geometry 1 July 26, 2010 02:10
Mesh Resolution in Gambit Vidya Raja FLUENT 2 January 19, 2006 00:35
Improving mesh resolution Vidya Raja FLUENT 1 October 13, 2005 14:52
Improving resolution of the mesh Vidya Raja Main CFD Forum 0 October 13, 2005 12:14
3-D Mesh Check in Gambit..... SHR FLUENT 4 March 25, 2003 04:10
