May 3, 2012, 14:55 |
#21 | |
Filippo Maria Denaro
Rep Power: 73 |
First of all, I suggest starting with an initial condition of uniform flow everiwhere (U= constant, V=0) and a linear pressur law along x |
May 5, 2012, 10:23 |
#22 | |
Dr. Madhukar M Rao
Rep Power: 16 |
Also, are you using split A or split B formulation for time-stepping (see Zienkiewicz's book) ? |
May 6, 2012, 15:55 |
#23 | |
Hector Redal
Rep Power: 17 |
I am using the split A formulation for the time-stepping. According to the reference (Zienkiewicz's book), this split allows the use of equal interpolation for the shape functions in quad elements. I am using shape functions for the velocity and for the pressure with equal degrees for both. |
May 7, 2012, 03:32 |
#24 | |
Dr. Madhukar M Rao
Rep Power: 16 |
[1] use a velocity/pressure element combination that satisfies BB. [2] ensure global mass conservation by adjusting the outlet velocity field such that the outlet mass flow matches the inlet mass flow. Best regards, Madhukar |
May 7, 2012, 13:51 |
#25 | |
Rep Power: 16 |
It seems that I did the same simulation work. I just set the all pressure conditions as zerogradient except the outlet one is fivedvalue 0. And the velocity is uniform: U=1 and V=0 at inlet, fixed wall is zero and outlet is zerogradient. the solution as shown in pic,the left down one is the velocity at inlet and right one is the velocity at x=4. I find the velocity at the inlet is not zero but half of the inlet. I am not sure if the solution is right or not. Thank you, Wei Last edited by hewei; May 7, 2012 at 16:11. |
May 7, 2012, 16:48 |
#26 | |
Hector Redal
Rep Power: 17 |
Firtst of all, I would like to thank you for your help and support. After this, I would like to mention that accorting to the reference (Zienkiewicz, chapter 3.4: Circunventing the Babuska - Brezzi restricction ), split A avoids any restriction on the nature of the two shape functions used for velocity and for pressue. As I have mentioned in an previous answer, I am using equal degree in both velocity shape functions and pressure shape functions. According to this reference: A finite element formulation for the Stokes problem allowing equal velocity-pressure interpolation. Ramon Codina - Jordi Blasco. Comput. Methods Appl. Mech. Engrg 143 (1997) 373 - 391, the use of equal velocity interpolation can be used in the CBS scheme algorithm. Consequently, a doubt arises to me at this point. If according to Zienkiewicz and Codina/Blasco this type of interpolation functions are feasible, why are they failing in my case? Kind regards. |
May 7, 2012, 16:50 |
#27 | |
Hector Redal
Rep Power: 17 |
I would like bring up the following question. Are you using the same algorithm than me for carrying this simulation? What I would like to know if you are using the CBS algorithm for the finite element method. Best regards, |
May 7, 2012, 18:11 |
#28 | |
Rep Power: 16 |
I used the OpenFoam to simulate the flow, as we know ,the OpenFoam is basically on FV method,I adopted the icoFoam to do that, so I am not sure this information may help you on FEM. yours, Wei |
May 8, 2012, 01:05 |
#29 | |
Dr. Madhukar M Rao
Rep Power: 16 |
Assuming that you wrote your own code, you can check the results against one of the freely available open source codes. Best regards, Madhukar |
June 2, 2012, 08:04 |
#30 | |
Hector Redal
Rep Power: 17 |
After struggling with the code, I discovered a bug in my code when assembling the force terms in the CBS Algorithm. The force term were correctly calculated, but the assembly utility failed to assemble the forces from each element. Once I have fixed this bug, I have re-run the test case. I am enclosing the results I have obtained. It appears to me that this are miles better than the ones I had previously got. What's your impression about these new results? I have also updated the results for the lid driven cavity flow. You can take a look at them in the following link: https://sites.google.com/site/hector.../cfd-example-1 I would like to thank all of you for your kind help and support. Thank you very much!!! Best regards, Hector Redal |
Laminar flow and wall roughness | junbbung | FLUENT | 2 | November 26, 2022 22:22 |
Laminar Flow | rvallejo | CFX | 1 | November 16, 2009 10:49 |
Laminar field as initial state for turbulent two phase pipe flow | kjetil | OpenFOAM Running, Solving & CFD | 3 | July 21, 2009 10:15 |
flow simulation across a small fan | jane luo | Main CFD Forum | 15 | April 12, 2004 18:49 |
Divergence of Laminar Flow With Eddy ??? | Peter Kostka | Main CFD Forum | 3 | May 9, 2002 18:02 |
