Renato- Imported volume from ProE
Old   October 6, 2005, 15:31
Default Renato- Imported volume from ProE
Vidya Raja
Hi Renato, I tried importing the solid as IGES, STEP and PARASOLID files. Still I get the same message that the subtraction operation cannot work on non- real geometry. Is there any way to tackle this problem. I imported the solid as a whole.
Thanks, Vidya
Old   October 6, 2005, 15:44
Default Re: Renato- Imported volume from ProE
Renato
I've forgot to mention in the last message but can you get some kind of report about your model after importing it? Most of the preprocessor softwares have reports to show you how many volumes, areas, lines, etc... were successfully imported or if your imported model has any kind of degeneracy.
Renato.
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 15:11
On the damBreak4phaseFine cases paean OpenFOAM Running, Solving & CFD 0 November 14, 2008 22:14
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 15:00
