CFD analysis with AcuSolve
Like Tree5Likes
Old   April 1, 2021, 09:05
Vignesh Lakshmanan
ViLaks is on a distinguished road
Dear Rishi,
I am working on HW CFD Platform. Is it possible to do structured meshing? Whenever I mesh, I just get polyhedral meshing. I need to use hex elements, whcih shall reduce my element count drastically.
With Regards
Vignesh
ViLaks is offline   Reply With Quote
Old   April 7, 2021, 02:57
Vignesh Lakshmanan
Originally Posted by ViLaks View Post
Dear Rishi,
With Regards
Vignesh
Hi Rishi,
My bad... I didnt explore all the options properly. I am now able to generate structured mesh.
Regards
Vignesh
Old   June 14, 2021, 07:30
Vignesh Lakshmanan
I have run a simple pipe flow problem in steady state using Acusolve. I would like to plot pressure vs flow rate.
I would like to do that using Acuprobe. I would export pressure , velocities and area from acuprobe, calculate flow rate and do the plot in Excel.
However, I am confused on which values to export - Solution Ratio/Surface Statistics/Surface Output.
Also there are initial, final and all; minimum and maximum for both pressures and velocities and I am getting confused.
Can someone guide me on this.
Also, can I directly plot this in Acufieldview?
Thanks
2d analysis, acusolve, incompressible flows, incompressible fluid
How do you do a fluent CFD analysis for a boat? UHMStudent FLUENT 2 July 24, 2011 13:45
CFD software capable of modal analysis? Jim-gineer Main CFD Forum 4 January 14, 2010 10:29
FDM vs FVM vs FEM in CFD analysis ck5285 FLOW-3D 1 September 1, 2009 11:51
ASME CFD Symposium, Atlanta, 22-26 July 2001 Chris R. Kleijn Main CFD Forum 0 August 1, 2000 11:07
CFD Analysis on Shock/Boundary Layer Interacton'-HELP Mujahid S. Suhaeb Main CFD Forum 8 December 1, 1999 18:14
