How could i improve an aircraft design using CFD?
Old   April 22, 2012, 10:06
Default How could i improve an aircraft design using CFD?
spk
spk is on a distinguished road
I have designed an aircraft studying Raymer's book. How could i improve this design using the 3d aircraft model and a CFD package?
Any ideas?
Thanks a lot!!
spk is offline   Reply With Quote
Old   April 22, 2012, 10:11
HMN
HMN is on a distinguished road
Originally Posted by spk View Post
Any ideas?
Thanks a lot!!
I am new here, but I think you should concrete more. CFD has a sample (tutorial) with a wing. I did it to learn how to work with the ansys workbench.
Regards
HMN is offline   Reply With Quote
Old   April 22, 2012, 10:19
spk
Thanks for the answer!
My question is how i could improve the design, studying the 3d aircraft geometry numerically with a CFD program!
For example studying the cp distribution along the wing, would be useful in order to improve the desing?
Any ideas about the results that i could take using CFD and would help me to improve aircraft design?
Old   April 22, 2012, 10:45
Aniket Sachdeva
thegodfather is on a distinguished road
U can definitely improve your design if you have a good cfd software and the required computing power at your disposal...
You can improve your wing design by simulating flow over the wing designed by you and changing some parameters like chord, span, nose radius etc. n study its effect on the lift-drag characteristics...
thegodfather is offline   Reply With Quote
Old   April 22, 2012, 11:31
spk
Thanks thegodfather!
I have studied lift-drag characteristics changing some parameters like chord, spn, etc using xfoil and profili! Using CFD program like fluent, i will have more accurate results?
Old   April 22, 2012, 13:57
Aniket Sachdeva
I am afraid I may not be the best person to answer this question...
I am just about to enter my senior year in mechanical engineering and have just started learning various numerical schemes to understand fluid motion...
I do not have a lot of experience in using cfd softwares... The idea of improving the design using cfd seemed just too appealing not to be given at least a try..
All the best... N do post if u succeed in improving it..
Old   April 22, 2012, 16:15
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
normally, the "optimization" techniques are used along with CFD softwares ... Cp, Cd, as well as other parameters can be used as target.
FMDenaro is offline   Reply With Quote
Old   April 22, 2012, 17:33
truffaldino's Avatar
truffaldino is on a distinguished road
If you are considering analysys of low reynolds number airfoils fluent will not give you better results than x-foil. Especially if you are using turbulence modelling of low-re airfoils you might have much worser results in comparison with x-foil.
As an example you can take a look at comparison of results by x-foil and Large Eddy Simulation at this link
http://persson.berkeley.edu/pub/uranga09iles.pdf
The results have the same accuracy for LES and x-foil, while, in the above case, LES will run for weeks on ordinary computer, while x-foil will do it in a fraction of second.
Truffaldino
truffaldino is offline   Reply With Quote
Old   April 23, 2012, 03:06
Joern Beilke
JBeilke is on a distinguished road
Just to get a start
http://www.beta-cae.gr/events/c4pdf/3B_1_papoutsis.pdf
JBeilke is offline   Reply With Quote
Future CFD Research Jas Main CFD Forum 10 March 30, 2013 13:26
CFD inverse design chitharenjan Main CFD Forum 0 August 13, 2010 09:38
CFD for fans & blower housings David Carroll Main CFD Forum 8 August 24, 2000 18:25
Evaluation for CFD software purchase Nasim Suleman Main CFD Forum 3 July 24, 2000 12:15
part-time-cfd Michael Main CFD Forum 6 February 2, 2000 13:01
