Very Basic Question
Old   April 18, 2012, 13:58
Default Very Basic Question
Gina
ghagler is on a distinguished road
When I use CFD, I input my variables and my output is either a series of numeric values that answer my questions OR a visual output that shows me the fluid flows and behavior of my model?
ghagler is offline   Reply With Quote
Old   April 19, 2012, 13:06
Mazhar Iqbal
mazhar is on a distinguished road
Depends on which software you use for your CFD analysis. If you use commercial softwares then sure they give you option of graphical display, however if you use your own code then you will get only numerics, which you will have to transform to graphics.
mazhar is offline   Reply With Quote
Old   April 19, 2012, 14:20
Yasin Besari Mustofa
yasinbm is on a distinguished road
by the way, What software do you use to solve your model?
yasinbm is offline   Reply With Quote
Old   April 20, 2012, 14:28
cfdnewbie
cfdnewbie is on a distinguished road
No, the output is always numerical, but depending on the software you are using, it might be represented as a visualization of these numbers. But the pretty pictures are just another layer of model/discretization with its own errors on top of the results from the numerics,
cfdnewbie is offline   Reply With Quote
basics
[Other] very basic question about createPhi.H feldy77 OpenFOAM Meshing & Mesh Conversion 2 November 22, 2011 09:16
Basic question to buoyantBoussinesqPisoFoam kriz OpenFOAM 2 June 12, 2010 04:35
Basic Question Abhi FLUENT 1 August 4, 2007 09:07
Basic question: UDF for wall heat flux Carl FLUENT 1 August 5, 2006 20:01
A Basic Question on ducted Flows! CFD User Main CFD Forum 4 January 8, 2005 07:17
