Inlet and outlet definition problems
Old   April 9, 2012, 20:32
Default Inlet and outlet definition problems
Ethan
ethanmcmillan is on a distinguished road
So I have been attempting to model a brake rotor with vanes for quite some time now. Initially I could not define an inlet and outlet for the rotor in the meshing, I assume because its a circular cross-section that does not appear as a plane to ansys.
Regardless, I then tried to add walls around a small section of the rotor and use the inner faces of the inner and outer radii walls to be my inlet and outlet. This appeared to work until I modeled it after calculations, where I found the the air is traveling into the metal parts of the rotor and avoiding the space I want it to flow, the channel between the inner and outer rotor face.... ugh.
My question is how can I define my inlets so it flows through the void/ channel in the rotor instead of through the solid metal... Can I do it without drawing inner and outer faces? any breakdown on how to do this would be fantastic. I am just not confident with this software yet...
Many thanks to the person who can help with this, I am going crazy.
ethanmcmillan is offline   Reply With Quote
flow control, flow distributor, inlet boundary, outlet boundary
Inlet and outlet boudary without wall between Janshi CFX 5 February 2, 2012 05:51
uncertain on model outlet definition mactech001 CFX 0 February 10, 2010 03:03
VOF Outlet boundary condition in cfd - ace JM Main CFD Forum 0 December 15, 2006 09:07
VOF for flow problems with inlet and outlet Jannifer FLUENT 11 April 6, 2006 15:56
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 06:13
