temperature and pressure dependent specific heat? |
April 5, 2012, 06:51 |
How to add pressure dependence in DEFINE_SPECIFIC_HEAT?
I'm doing with plasma, Cp varies with T and P drastically..... Thank you for any suggestion. |
April 5, 2012, 07:08 |
misagh
Rep Power: 14 |
hi.im not sure.if it was dependent to only T it was easy.but now with T and P dependence i think UDF will work.
April 18, 2012, 13:16 |
specific heat func. of temperature
OscarD
Rep Power: 15 |
I'm working with plasma modeling and require thermodynamic properties of argon as a function of temperature (at least, but it should also be pressure dependant).
I did a simple UDF for the specific heat, but it keeps giving me the same error once I try to initializate the calculation: "Warning: Incorrect Specific Heat value" the UDF is: DEFINE_SPECIFIC_HEAT(SpecHeat_Ar,T,Tref,h,yi) { real SpecHeat,a1,b1,c1,a2,b2,c2; real x = T/1000.; /*input temp in kK*/ a1 =8.064;b1 =13.92;c1 =2.721;a2 =2.907;b2 =28.19;c2 =19.67; SpecHeat = a1*exp(-pow(((x-b1)/c1),2.)) + a2*exp(-pow(((x-b2)/c2),2.)); SpecHeat=SpecHeat/1000.; /* the specific heat material property value is in [J/kg-K]*/ return SpecHeat; } I used similar eqs for thermal conductivity and viscosity. Does anybody what could be wrong?. Thanks |
December 16, 2012, 03:10 |
SSL
Rep Power: 15 |
I have the same problem when injected particles get vaporized, the warning "incorrect specific heat value" occures.
Any solution? |
December 18, 2012, 10:46 |
Rep Power: 14 |
Hi
I made a Service Request and Fluent answered that it is NOT possible to write an UDF with pressure-dependend Specific Heat right now. I hope they will change this in the future. I tried it on my own, DEFINE_PRPERTY works fine but DEFINE_SPECIFIC_HEAT is crap. Use the USER FORTRAN in CFX |
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 06:21 |
Simulation of a single bubble with a VOF-method | Suzzn | CFX | 21 | January 29, 2018 01:58 |
Water subcooled boiling | Attesz | CFX | 7 | January 5, 2013 04:32 |
error message | cuteapathy | CFX | 14 | March 20, 2012 07:45 |
Constant velocity of the material | Sas | CFX | 15 | July 13, 2010 09:56 |
