Cant access boundaries in fluent
Old   April 5, 2012, 04:16
Exclamation Cant access boundaries in fluent
Jurish
jurishali is on a distinguished road
Meshed a straight wing in rectangular prism volume.
Specified the faces and boundary types in Gambit.
When loaded into fluent, it shows that it skipped all the boundaries, so that 'Define Boundary Condition' options in Fluent doesn't show any faces, just the fluid volume and a wall.
jurishali is offline   Reply With Quote
Old   April 5, 2012, 05:35
kingjewel1 is on a distinguished road
Are you sure you exported the mesh in Gambit after assigning the boundaries, not before? I've sometimes done that
kingjewel1 is offline   Reply With Quote
Old   April 8, 2012, 09:36
Thumbs up
Jurish
Figured it out! I had constructed an outer elliptical cylinder over the wing with the same height as the span, so there was some discrepancy with the wing's end faces and the cylinders faces.
The problem vanished once I had increased the cylinder height, providing clearance between the wing and the outer cylinder
fluent, gambit, import
Two questions on Fluent UDF Steven Fluent UDF and Scheme Programming 7 March 23, 2018 04:22
CGNS import in fluent - periodic boundaries. Bjarne Børresen FLUENT 2 April 25, 2013 12:12
Fluent Access Violation error after a specific iteration number willyCEP FLUENT 11 August 29, 2012 13:10
Fluent 6.3.26 vs 12.1 and partition method Anorky FLUENT 0 April 27, 2010 11:55
solving ocean wave with Fluent or CFX? gholamghar Main CFD Forum 1 March 21, 2009 13:49
