gas solid flow in circulating fluidized bed with different gas velocity
Old   April 4, 2012, 16:29
Default gas solid flow in circulating fluidized bed with different gas velocity
kong
kongl1986 is on a distinguished road
Hey
i am simulating gas solid flow in circulating fluidized bed with different gas velocities.
my problem is that when i decrease the gas velocity at inlet, the solid volume fraction near the wall decreased and solid volume fraction in main flow area increased.
As i found in literature, lower gas velocity should lead to higher volume fraction in the whole radial profile.
Is there anyone has this experience or some suggestions?
thank you.
the wall condition is that: specularity coefficient:0.000135, j-j restitution coefficient 0.9
kongl1986 is offline   Reply With Quote
Old   April 4, 2012, 22:13
Musango Lungu
Musa is on a distinguished road
During the the start up of the simulation i.e. first 5 seconds it is normal to obtain such a result. For how many seconds have you been running your simulation? Try running it for a long time say 20 seconds and average the last 15 seconds. It also depends from which position you are getting your result. Try and get the result at a position where the flow is fully developed.
Musa is offline   Reply With Quote
Old   April 5, 2012, 23:23
kong
thank you for your reply Musa.
I found the reason that the solid inlet velocity i input is too big which is close to the gas veloticy, when i turn it down , and increase the inlet solid volume fraction to keep the solid flux same, the change is acceptable.
thank you again
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 06:21
circulating fluidized bed Özgür Baysal Phoenics 10 April 29, 2014 09:39
Flow behaviour of fluidized bed venkat FLUENT 1 September 3, 2008 22:16
Dispersed Solid particles in carrier gas (DPM) Frederik FLUENT 1 June 3, 2008 06:13
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 10:11
