3d wing analysis in fluent !! urgent help . beginner
Old   April 4, 2012, 00:34
Angry 3d wing analysis in fluent !! urgent help . beginner
Dinesh Singh Rawat
sam15 is an unknown quantity at this point
I am doing a 3d wing analysis
of a wing with chord 30 cm and span 40 cm . I have completed the
meshing in gambit now i want ot do analysis in fluent.
My flow speed is 50 m/sec, RE= 1.01* 10^6(turbulent flow). please tell me the
1- which solver i use??
2-which viscous model??
3- boundary conditions ??
4- how do we get the lift and drag values in fluent after iteration??
I am a basic user . I will be thankful to u.
sam15 is offline   Reply With Quote
Old   April 4, 2012, 08:56
Zigainer is on a distinguished road
Have you done any tutorial (e.g. "Modeling External Compressible Flow")?
And start reading the manual! Your question are really basic and if you don't know why you choose this and that BC/viscous model, you have no idea of what you get in the end and if the results are reasonable!
1. pressure-based
2. maybe the Spalart-Allmaras model or k-w SST Transitional
3. pressure inlet - pressure outlet
4. -> manual
Zigainer is offline   Reply With Quote
Old   April 5, 2012, 22:35
Dinesh Singh Rawat
hey thanks ............. i applie d all the conditions and iterated it...........but i am not getting the stalling point on the wing............
Old   April 6, 2012, 03:56
Abdulqadir Aziz
aqstax is on a distinguished road
Have you tried the tutorials from cornell?
aqstax is offline   Reply With Quote
Old   April 11, 2012, 11:49
kdrbrk's Avatar
Burak
kdrbrk is on a distinguished road
Try velocity values on the surface, and where it goes to negative from positive, than you can understand that flow detaches from surface and reverse flow happens.
kdrbrk is offline   Reply With Quote
Old   May 25, 2012, 01:30
Abdulqadir Aziz
You don't need to use velocity for that. Just look at shear stresses on surface. Where it is 0 is where detachment has occurred.
Old   June 21, 2012, 15:21
Hannah Mac
hannah72206 is on a distinguished road
You should be able to change the angle of attack by rotating the geometry in Design Modeler. Then run that rotated design through the solver and when your lift coefficient starts going down, you know you've reached your stall angle.
hannah72206 is offline   Reply With Quote
Old   August 3, 2012, 07:01
Default velocity inlet in fluent
hhh
kunar
hhh is on a distinguished road
Dear friends,
In fluent, For analysis of 2D naca0012 airfoil velocity inlet we give vcostheta in x component & vsintheta in y component, v is inlet velocity.
1)here i start analysis of 3D wing, for that i take naca 0012 airfoil chord '1'& extrude 100mm, in gambit and analysis in fluent i have doubt how to set velocity inlet, here i consider my velocity is 3m/s, then what is xyz component in inlet velocity boundary condition,please let me know.
2)if you consider 3D wing, (vtantheta for z component) is correct or wrong, please let me know.
2) how to find angle of attack for 3D wing? please let me know
hhh is offline   Reply With Quote
3d wing
How to carry out 3D shell and Tube Heat Exchanger analysis in fluent medogalal FLUENT 3 December 30, 2015 05:28
2D Fluent CFD Analysis lamboram FLUENT 0 July 12, 2011 14:02
How to find Lift/Drag ratio of a compelx wing in FLUENT kjayatunga FLUENT 2 August 31, 2010 05:02
Looking for an aircraft wing model in FLUENT mimi Main CFD Forum 0 May 10, 2007 05:03
Urgent help needed- FLUENT to ANSYS Omer Main CFD Forum 3 September 18, 2006 11:24
