gas-liquid slug flow in horizontal pipe
Like Tree7Likes
Old   January 22, 2013, 00:01
Vaze
mvee is on a distinguished road
Hi Kanarya
What is difference between the velocity at exit and inlet? Will it remain constant? - if yes then check UDF
or inlet velocity remain small and constant irrespective of exit velocity - then you can not use Adjust function because this function might not be updating the inlet velocity at every iteration. Hence you will have to implement the updates in inlet velocity with some additional macros or loops.
Best wishes
Mvee
mvee is offline   Reply With Quote
Old   July 15, 2014, 07:35
Default people help me
  #22
modheji
modheji is on a distinguished road
Hi guys.
I am student . I want to simulate solid-Gas flow (two Phase) in Horizontal pipe by Fluent and in next step I want to make it and compare all result .It is very important for me.
I try to simulate in fluent but unfortunately I couldn't. Could you please help me for design.
( please step by step or in a complete example )
Ex:
1- Define>model>multiphase
2-Define>...
3-...
with best wishes
Modheji
modheji is offline   Reply With Quote
Old   January 26, 2020, 06:55
hella
hellaadouni is on a distinguished road
I'm working on a horizontal air-water confined flow, and I got the slug flow. The problem is when the slug hits the upper part of the channel and blocks the air, this air must return as I think. But it doesn't. Do you have an explanation for this?
I'm sure that the air doesn't return because the air BC is velocity inlet, but I really want to understand where did the air goes once a slug blocks its passage to the outlet?
I'll be grateful if you help me.
Thanks
hellaadouni is offline   Reply With Quote
Old   January 26, 2020, 06:57
hella
Originally Posted by kbaker View Post
Slug can obtained from stratified flow but the point of transporting stratified to slug depend on the phase velocities (especially higher gas velocity give slug flow) hence if you get stratified flow successfully just increase the gas velocity then with progress of the run with time you will get it? furthermore you need to check the range of your phase velocities that fulfill slug flow refer to any flow regime map to check it and I prefer that given by Taitel & Duckler Flow regimes map for horizontal pipes.
kbaker
Hey Mr Kbaker,
I'll be happy if you help me.
Thanks
gas-liquid, horizontal pipe, slug, two-phase, volume fraction
Slug flow in a vertical pipe Abe FLUENT 0 March 29, 2007 10:01
gas solid pipe flow tahar Phoenics 6 November 3, 2003 13:03
Gas Liquid flow in a packed column Rakib FLUENT 8 June 18, 2002 02:58
fluid flow fundas ram Main CFD Forum 5 June 17, 2000 22:31
Hydrostatic pressure in 2-phase flow modeling (long) DS & HB Main CFD Forum 0 January 8, 2000 16:00
