March 26, 2012, 12:30 |
FLUENT negative volume
Rep Power: 15 |
I have developed a fairly complex mesh in ANSA. When I do a mesh check in ANSA for negative volumes, it does not detect any. When I load the .msh file into fluent however, and do a mesh check there, it finds the minimum volume to be negative. Does anyone know if fluent can somehow display visually, or just spit out the xyz coordinates of where this negative volume is located so I can check it out in ANSA?
thanks |
March 27, 2012, 05:03 |
Vangelis Skaperdas
Rep Power: 21 |
Hi there,
Have you checked the mesh quality in ANSA to see if there are any skewed elements? Which ANSA version are you using? Could it be that you have very small length scales and you need to run the double precision version of Fluent? Best regards Vangelis |
Negative cell volume detected, dynamic mesh | tony25800 | FLUENT | 6 | September 17, 2014 20:50 |
Negative Volume during Mesh Motion Analysis | giov_ingr | FLUENT | 2 | December 13, 2013 07:09 |
Dynamic meshing in CFX: (negative volume error) | vmlxb6 | CFX | 6 | August 28, 2010 07:43 |
blockMesh error ... | balkrishna | OpenFOAM Pre-Processing | 0 | August 17, 2010 03:39 |
Negative volume in mesh motion | skarp | CFX | 5 | July 12, 2007 00:51 |
