Quenching simulation : how to set up a conjugate heat transfer between solid&liquid |
October 17, 2012, 15:46 |
#21 |
dking
Rep Power: 14 |
Yes, you must mesh the solid part as well so that Fluent can solve for the temperatures at each node in the solid (via the heat conduction equation). When you mesh the solid, the fluid/solid interface nodes have to match as well.
October 17, 2012, 16:07 |
#22 | |
Ehsan Asgari
Rep Power: 18 |
Dear dsking, I have either meshed the solid zone, but Fluent does not solve the heat transfer at all. Would you help me to understand what is wrong? tnx |
August 30, 2013, 10:05 |
Solution
#23 |
Ehsan Asgari
Rep Power: 18 |
Despite it's been a while since the last comment, I decided to back on the thread and share the solution.
Conjugate heat transfer (2D) does happen but very slowly in laminar flow. If you want to see the final solution, solve the problem in steady-state mode. If you select a proper turbulence model you can easily watch both solid & fluid changing temperature in a transient solution. Therefore there is no need to convert the geometry to 3D. I hope this can help. |
March 15, 2015, 00:19 |
#24 |
Aviskar Dhaval Solanki
hi everyone,
i am Dhaval solanki doing simulation on fin heat transfer from engine cylinder. Here i have coupled fluid solid mesh for conjugated heat transfer between interface. Now i am facing problem in giving constant temperature boundary condition inside cylinder wall, because if i give constant temperature at wall created by conjugated coupled option, it will decouple the wall from fluid. other one is i am new fluent user i also want to know how to get heat transfer co-efficient and heat flux graph with respect to streamwise direction.. thanks |
August 30, 2016, 07:33 |
#25 |
RAVI KARAN TRIPATHI
Rep Power: 12 |
Hello everyone,
I am also facing the same problem in CHT modeling (2D case) in fluent. here i have one hot cylinder (250c) and another cylinder is placed beside hot cylinder. air with velocity 100 m/s at 30c is flowing over the cylinders. now i want to find the temperature of the second cylinder because of convection. i have made grid in solid portion also. Thanks in advance. |
conjugate heat transfer, fluent, quenching |
Water subcooled boiling | Attesz | CFX | 7 | January 5, 2013 04:32 |
Heat Flux at wall in a conjugate heat transfer problem | Chander | CFX | 2 | July 9, 2011 23:22 |
Conjugate Heat Transfer | boathead | STAR-CCM+ | 1 | April 15, 2011 10:13 |
Conjugate heat transfer with periodic boundaries | Suresh | FLUENT | 0 | February 23, 2009 10:51 |
