March 24, 2012, 11:38 |
check results...
#21 |
andres
Rep Power: 16 |
Hi Banty,
look at this... 87 seconds and the tanks still full with air and pressurized... no way... I started with time step 0.1 then 0.5... then 1 then 5... nothing... results are pretty much the same Please see pictures of parameters, residuals and results... I do appreciate your help! Thank you |
March 28, 2012, 14:31 |
#22 |
banty
Rep Power: 14 |
something wrong with the solver setting or mesh or even in physical problem modeling because solution is not converging (residuals ~ 10^-1). Would u once check with very fine mesh. |
March 29, 2012, 15:50 |
#23 |
andres
Rep Power: 16 |
mesh is ok because I have a 97% of element quality, low skewness, and fine aspect ratio.
A finest mesh will make me require a parallel process... have you ever tried to solve a discharging process? if you want to you can design a 52ft high and 12ft diameter. Discharge air from 150psi to a 42" line Thank you Banty |
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 06:21 |
Calculation of the Governing Equations | Mihail | CFX | 7 | September 7, 2014 07:27 |
error message | cuteapathy | CFX | 14 | March 20, 2012 07:45 |
Force can not converge | colopolo | CFX | 13 | October 4, 2011 23:03 |
Constant velocity of the material | Sas | CFX | 15 | July 13, 2010 09:56 |
