BC problem: modelling ground as a porous material
Old   March 17, 2012, 14:25
Unhappy BC problem: modelling ground as a porous material
CH. Lee
cryfreer is on a distinguished road
As shown in the attached figure, ground and well is modeled (axisymmetric) as a porous material using laminar flow, energy equation and some UDF for the porous resistances. There is only one phase (water).
Because of ground water flow from the outside boundary, I choose the pressure inlet BC for the outside and bottom boundary (upper boundary is modeled as a wall).
: 1 velocity inlet, 1 outlet at well surface. porosity = 1 in the well, porosity < 1 in the ground.
Q1: To model the hydrostatic pressure due to the gravity, I checked the gravity box and specified operating density (=0). In that case, I can see a pressure distribution with depth direction. However, if I use 998.2 kg/m3 as the operating density, can I get pressure head through the analysis? Because, in this case, pressure = 0 at the whole domain from the result.
[gradient of groundwater flow is calculated in the total head difference in the aspect of groundwater. total head = potential head (due to the gravity, location) + pressure head + dynamic head (in most cases, = 0) ]
Q2: For the outside and bottom boundary, I used a gauge pressure = 0 at boundaries. Is that reasonable?
I can see many reverse flow faces in this case at the pressure inlet boundary with operating density = 998.2 kg/m3.
Also, I've tried to give a reverse pressure to the boundary for the equal pressure in the ground using simple UDF ( (height - location) * 998.2 * 9.81 ). This is for the equal pressure at the boundary to model pressure head.
How can I model the pressure which is only due to the pressure head not static pressure? Any suggestions?
Thanks
cryfreer is offline   Reply With Quote
Old   March 17, 2012, 19:54
CH. Lee
Problem solved using UDF, Thanks
Old   March 19, 2012, 02:14
Abdul Halim
abdulhalim060189 is on a distinguished road
Originally Posted by cryfreer View Post
Thanks
excuse me sir, I'm also working in porous media, but I can't definite it. May be can you help me? my email is abdulhalim060189@yahoo.co.id
abdulhalim060189 is offline   Reply With Quote
boundary condition, porous media
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 06:21
Modelling Combustion in Porous Zone tanjinjack FLUENT 2 September 26, 2016 05:10
Porous media solving problem mulfal OpenFOAM Running, Solving & CFD 2 June 23, 2010 06:31
Ammonia-liquid modelling. Problem with thermal expansion coefficient. zhekka FLUENT 0 February 9, 2010 16:06
Simple Porous Problem Abdul FLUENT 0 October 31, 2005 19:30
