Unsteady flow and DPM
Old   March 17, 2012, 06:48
Smile Unsteady flow and DPM
Dr. Moloy Kumar Banerjee
moloykb is on a distinguished road
I want to study the behavior of the particle under the unsteady flow. Consider a situation where the flow through a pipe in pulsatile in nature, say at the inlet to the pipe, the velocity is given as V=V_0*(1+sin(w*t)). If I solve the unsteady Fluent Solver, it will give the result, but what happens if I wants to solve the DPM along with this.
For, steady flow like V=V_0, first the eulerian flow field has to be solved, then we switch on the DPM. Now, how to implement this in case of pulsatile problem.
Thanks in advance.
moloykb is offline   Reply With Quote
Old   March 17, 2012, 15:21
Domenico
doronzo is on a distinguished road
hi
do you mean how to set up a pulsatile injection of discrete phase, or just to couple any injection to a pulsatile eulerian phase?
regards
doronzo is offline   Reply With Quote
Old   March 17, 2012, 20:28
kingjewel1 is on a distinguished road
1) Get your solution converged in Transient form.
2) Turn on your DPM and then click on 'unsteady particle tracking' under the DPM setup.
Solve for further time periods.
This will solve particles alongside your momentum, etc equations.
kingjewel1 is offline   Reply With Quote
Old   March 21, 2012, 00:52
Dear kingjewel1
Thaks for your reply. Once I solve the pulsatile eulerian then if i turn on the DPM, then how the fluent will take the same flow solutions for Lagrangian tracking of the particle?
Old   March 21, 2012, 00:55
Dear doronzo
Thanks for the reply. I wants to couple the injection with the pulsatile flow.
Old   March 21, 2012, 04:28
Originally Posted by moloykb View Post
Dear kingjewel1
Because you need to turn on 'UNSTEADY tracking' in DPM:
Models>DPM>click unsteady particle tracks
and solve the particles at the same time as the flow equations.
You could even do this right from the very beginning but I'd allow at least one cycle to elapse before you did.
unsteady DPM and steady flow Mohsin FLUENT 6 October 9, 2014 06:30
DPM transient laminar flow over a cylinder JSoares FLUENT 1 April 12, 2011 03:37
DPM and High speed air flow John FLUENT 0 January 15, 2008 12:17
unsteady DPM Thiyagarajan FLUENT 4 August 23, 2005 15:06
steady or unsteady? (in dpm) winnie FLUENT 1 April 28, 2003 12:30
