How to simulate flows between two counter-rotating disks in a chamber? |
March 16, 2012, 13:50 |
Hello folks:
I am trying to simulate flows between two counter-rotating parallel disks (open at the rim) inside a static cylinder chamber. I know I can use sliding mesh by applying an interface (1) between the disks. But since there will also be relative motion between the disk and the static chamber, do I also need designate interfaces between the disk grids and the chamber grid, i.e., interface (2) and (3) for the two disk grids? Then Interfaces (2) and (3) will be normal to interface (1). Please help! |
March 18, 2012, 22:45 |
#2 | |
Rep Power: 16 |
Hi Poon,
I think you can try Multiple Reference Frame (MRF) first for steady-state simulation first. You need to create two volumes to enclose two rotating disks respectively. Then you can define interface (2) and (3) you mentioned as interior. You don't have create interface (1). Hope this can help. Sunflower Quote:
June 22, 2015, 03:31 |
#3 | |
Marya A
Rep Power: 11 |
Hi Pooh,
Did you solve the problem? Could you give me a comment how did you solve it? I am struggling with the same case. Quote:
sliding mesh |
Simulate mixing of two different flows in FLUENT | Masood | FLUENT | 1 | June 25, 2007 12:46 |
Can Fluent be used to simulate IC engine flows? | Jimmy Fox | FLUENT | 1 | September 7, 2005 11:35 |
axisymmetric model of two rotating disks cavity | liaolingling | FLUENT | 0 | April 27, 2005 05:24 |
Rotating Flows and Ekman BL | David Stanbridge | Main CFD Forum | 4 | February 7, 2002 00:14 |
Rotating Flows | David Stanbridge | FLUENT | 3 | August 24, 2000 15:03 |
