Eulerian Model - properties
Old   March 15, 2012, 23:47
Default Eulerian Model - properties
Kim Donghee
ssamton is on a distinguished road
Dear all
I have a question about properties in multiphase flow, Eulerian model.
Manual described that Momentum and continuity equations are solved for each phase.
What does it mean exactly?
If primary and secondary phase exist in same cell, how calculate properties in fluent?
I think since equations are solved for each phase, does not affect each other.
if primary phase is 0.8, i.e, secondary phase is 0.2, and density of each phase are 100 and 1000, density is 0.8*100 + 0.2*1000=280 in cell?
or does not affect?
Just use 100 for solving the primary phase and use 1000 for solving secondary phase?
I wish listen your comments
Thank you all
Bests
ssamton is offline   Reply With Quote
Old   March 16, 2012, 02:34
chenxizhong
chenxizh is on a distinguished road
The Eulerian model is Momentum and continuity equations are solved for each phase. That means if you have two phase such as gas-solid, you will sovle two eqution for gas(use the denstiy of gas ), and two eqution for solid (use density of solid ).
Other model named Mixture model is available in fluent ,too. In Mixture if you have two phase, you just solve two eqution, that is mixture of gas and solid used density 280 you mentioned.
chenxizh is offline   Reply With Quote
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 06:21
Eulerian Multifase model with species transport Valeria FLUENT 0 July 19, 2008 17:48
Eulerian porous model kevin FLUENT 0 December 3, 2006 11:45
the interface bc in Eulerian Model lily FLUENT 0 July 28, 2005 03:37
DPM + Eulerian Model Shane FLUENT 2 July 14, 2004 09:26
