Heat transfer problem
Old   March 15, 2012, 06:28
Default Heat transfer problem
prince
prince_pahariaa is on a distinguished road
Hi friends..
I am trying to solve heat transfer problem but i am not getting temperature distribution as expected.
Problem consist of one outer pipe of 67mm dia and two inner cylindrical cup of dia 26mm and 28mm and of height 40mm and 20mm respectively. heat is generated (15W) inside the 26mm cup (height of cup at which 99% most of the heat is generated is 6mm).
I have given boundary condition as velocity inlet 0.18m/s (given in problem) and pressure outlet (1 atm) as boundary condition. There is stagnant water between two cup. I am expecting maximum temp at the wall of inner cup (28mm dia cup) is 333K (through rough hand calculation) but i am getting much lower value 303K.
I will really appreciate any help.
prince_pahariaa is offline   Reply With Quote
Old   March 15, 2012, 06:45
Zigainer is on a distinguished road
Have you changed your operating pressure?
Or did you want 2 atm at the outlet?
Zigainer is offline   Reply With Quote
Old   March 15, 2012, 08:03
prince
Hi Zigainer
No, I dont want 2 atm pressure at outlet. I have kept operating pressure as 101325 Pa and in defining boundary condition for pressure outlet, i have taken gauge pressure 0.
Heat transfer problem at nucleate boiling MrStuebb FLUENT 12 March 14, 2017 14:31
Natural Convection heat transfer problem srinivasa FLUENT 21 November 11, 2016 07:08
Wall heat transfer coefficient (HTC) problem Mohamed khamis CFX 1 January 16, 2010 00:12
How can I increase Heat Transfer at Domain Interf? B.Simon CFX 3 October 28, 2008 19:53
Heat Transfer Problem Help JB FLUENT 2 October 18, 2006 19:54
