How to determine time step size and Max. iterations per time step.
Like Tree66Likes
Old   March 6, 2012, 15:41
Default How to determine time step size and Max. iterations per time step.
Pratik
pratik c is on a distinguished road
I am trying to simulate airflow through a room and am performing a transient calculation. Could someone please tell me how to determine time step size and max iterations per time step?
pratik c is offline   Reply With Quote
Old   March 7, 2012, 04:47
ghost82's Avatar
Rick
ghost82 will become famous soon enough
A rule of thumb is to set time step< deltax/u
where deltax is the smallest cell size and u is the velocity.
Usually I set max iteration per time step equal to 50 or 100, depending on residual values (if I want convergence at 10^-3 ^-4 I set near 50, if I want 10^-7 closest to 100).
Daniele
ghost82 is offline   Reply With Quote
Old   March 7, 2012, 05:38
Pratik
Sorry I am quite new to this. Could you please tell me how to determine the smallest cell size?. And also what number of time steps would I need?
rgd and Sittisak like this.
Old   March 7, 2012, 05:52
ghost82's Avatar
Rick
Pratick,
the smallest cell size can be determined from your grid.
If you have done your grid with your pre processor, gambit for example, you know what is the cell size, and where your domain is more refined.
If you have for example one of the smallest quad cell measuring 0.001x0.005, then your smallest cell size will be 0.001.
If you have tri cell then take the smallest side of the cell.
The total number of time steps depends on your simulation: it can be 1 s or 20 s (i.e. total number of time step=1s/timestep or 20s/time step), it depends on your system and on what you are looking for.
If this is your case, you can estimate and take into account a transient period and a period in which your system reaches a pseudo-steady state.
Daniele
saha2122, silverra1n, rgd and 10 others like this.
Old   March 7, 2012, 06:28
Pratik
Thank You Danielle.
Old   March 9, 2012, 16:20
duri
duri is on a distinguished road
This is correct for explicit schemes but solver take cares of it. In case of implicit solver we can go for higher time steps (>100 times). This results in faster solution.
Start with some characteristic length to characteristic velocity ratio. Reduce or increase the time step by an order based on the no. of iterations it takes to converge.
sherlock and dhein like this.
duri is offline   Reply With Quote
Old   March 11, 2012, 05:59
sanjay
sudhir.iisc is on a distinguished road
Hi Daniele,
It would be better to adjust the time step such that maximum iteration/time step not more then 20. If Solution is not converging within this pseudo time step (iteration) then prefer to decrease physical time step.
Daniele
sudhir.iisc is offline   Reply With Quote
Old   March 12, 2012, 11:42
cfd seeker is on a distinguished road
I want to ask what is the role of Courant No. in determining the time step size??
As we know Courant No. = velocity*delta(t)/delta(x), by this equation time step size is directly proportional to Courant No, so can we use bigger time step size by increasing the Courant No. ???
cfd seeker is offline   Reply With Quote
Old   March 13, 2012, 14:02
banty
banty is on a distinguished road
But in case of wave tracking, even with the implicit solver time step should be taken such that wave should be not move more then one cell in single time step.
banty is offline   Reply With Quote
Old   March 13, 2012, 14:25
banty
Role of Courant no depends upon the solvers setng.
In case of pressure based and density based (both explicit and implicit) solver with backward euler (1st and 2nd order), time step(physical time step) is entered by the user based on physics involved and CFL no & no of sub iteration decides the speed of convergence.
But in case of explicit-explicit density based solver, time step (physical time step) is decided by the CFL no (User Input) and based on Courant No. = velocity*delta(t)/delta(x).
Old   March 13, 2012, 15:52
duri
Yes you can use but it can only control the time step size of inner iterations. It will help in faster convergence of inner iteration but remember there is a restriction on this value due to numerical stability (even for implicit). In unsteady problem physical time steps are more important that numerical time steps to capture a phenomenon.
Old   March 18, 2012, 23:34
Mahindra
mahi007 is an unknown quantity at this point
Hello
I am doing analysis of flow past circular cylinder. Can anyone suggest me what are the solver settings?
And how to calculate time step?
Regards
Mahindra
mahi007 is offline   Reply With Quote
Old   June 19, 2013, 08:10
Yash Ganatra
yashganatra is on a distinguished road
Is it steady state or transient?
yashganatra is offline   Reply With Quote
Old   June 19, 2013, 12:09
Default time step
  #14
Tanjina Afrin
Tanjina is on a distinguished road
I have also similar question, but couldn't find any definite answer. i am trying to model a flow through a circular pipe from a rectangular reservoir. I used workbench for meshing. It's triangular mesh. element size is 6e-3m. How can I determine time step. I modeled 3D. I couldn't find any option called iteration/time step, but in may tutorial I saw it.
Tanjina is offline   Reply With Quote
Old   June 20, 2013, 03:31
Yash Ganatra
Post some more details. Attach photos of the mesh.
1. Is it steady state or transient?
2. Laminar or turbulent?
You can find the option in FLUENT in the Run Calculation settings in the Problem Setup tab on the left
Old   June 20, 2013, 11:03
Tanjina Afrin
This is 3-D transient time, turbulent two phase flow problem . I have attached two photo with this reply. please have a look on calculation setting photo.
More details : I want to let the water flow from the reservoir to circular pipe and let air fill up the empty place of reservoir which will be created after water going to reservoir.
Old   June 20, 2013, 13:15
Yash Ganatra
I see that divergence is being detected? For which quantity (momentum,energy etc) it is getting detected? Are you using VOF Model?Can't this be done in 2D also?Give snaps of Solution Methods and control ; from what I make out by referring to various threads, if the solution is not converging better to reduce time step.
See literature - a similar problem, what was the time stepping used ;
Old   June 20, 2013, 18:16
Tanjina Afrin
At First, it showed AMG divergence: x-momentum. then I reduce momentum in relaxation factor from 1 to 0.7, 0.1. then model completed its run. But residual is not decreasing. its increasing with saw tooth shape.
yea I have used VOF model. Actually pipe is circular and tank is rectangular, so I didn't understand how can I model it in 2D.
Please find the screenshot of solution method and control.
Old   June 21, 2013, 02:34
Yash Ganatra
What I meant was that you can model the cross section. Why have you used Non Iterative Time Advancement? I have never worked with it so I have no idea about this. Check if your boundary conditions are correct.
Are those the default solution methods?
I did a quick search and found this thread. Hopefully it will help you.
http://www.cfd-online.com/Forums/flu...-momentum.html
Old   June 21, 2013, 15:15
Tanjina Afrin
I just followed the step described in Tutorial 20, ink jet problem. My problem was little bit similar to that. That's why I used non -iterative time advancement.
I reduced under relaxation factor, after doing that model run its full time step I specified, but result was not expected.
I think I make some mistake in inlet BC. Can you suggest me anything about BC?
I can describe what I want to model and what I used in BC if you are interested.
Time step size and max iterations per time step pUl| FLUENT 31 October 23, 2020 23:50
icoLagrangianFoam OF1.6 myNewParticleSolver heavy_user OpenFOAM 23 June 2, 2020 03:18
Transient simulation not converging skabilan OpenFOAM Running, Solving & CFD 14 December 17, 2019 00:12
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 06:36
Time step size, number of time steps and max iterations per time step guido_88 FLUENT 4 August 30, 2012 15:49
