How to determine time step size and Max. iterations per time step. |
November 25, 2016, 06:33 |
#41 |
October 23, 2017, 04:03 |
Simulation Runtime
#42 |
Vignesh Lakshmanan
Rep Power: 10 |
Dear All,
Sorry for restarting the thread, I just need to know the total time my transcient simulation ran in Fluent. Following are the parametrs I gave as input: Time Stepping Method: Fixed Time Step Size (s) : 0.5 No: of Time Steps : 200 Max Itr/Time Step: 20 Is it right that my simulation has run for (200*0.5) 100 s ?? If yes, then my simulation is wrong. I am simulating natural convection inside a deep freezer whose walls are at -20 deg celsius and air inside is at 43 degree celsius. I need to calculate time needed for air to cool down to -18 deg celsius. If the simulation is run for 100 s, I get the result. But it is wrong right. 43 to -18 deg celsius in just 1.5 mins? Thanks and Regards Vignesh |
October 23, 2017, 05:03 |
#43 |
Alexander
Rep Power: 34 |
(200*0.5s) = 100s
Best regards |
March 26, 2018, 15:26 |
#44 |
erfan
Rep Power: 8 |
hi i have problem to find non dimensional time step
this formul is ut/D and D=0.04 , U According to Re=100 dansity=1000 and viscosity=0.001002 it will be obtained U=0.0025m/s non dimensional time will bw obtained 77 how can do it? |
February 26, 2019, 22:38 |
#45 |
MWRS
Rep Power: 8 |
If we have the smallest grid size at high Mach approximately in the magnitude 10^7 (y plus), then the time step size would be even lower (~10^10) and Courant would be crazy high, according to the formulation described above. Am I right?
February 26, 2019, 23:50 |
#46 |
duri
Rep Power: 17 |
Courant number is a scaling factor. T=C X/abs(u)+a C is 1 is the fastest wave travels a distance of X.
January 21, 2024, 13:21 |
number of iterations and time step and setting boundary condition
#47 |
Lokesh Verma
HI,
I am new to ansys, i am simulating a liquid piston compressor i.e. water is used to compress gas inside cylinder. i am applying velocity inlet boundary condition with gauge pressure (30 bar) (the inlet is water completely), inside the gas is at 7 bar. I want the simulation to stop when pressure of air gets equal to water pressure i.e. 30 bar. how to set up boundary condition?? Also how to choose number of iteration and time steps?? Thanks in advance |
Time step size and max iterations per time step | pUl| | FLUENT | 31 | October 23, 2020 23:50 |
icoLagrangianFoam OF1.6 myNewParticleSolver | heavy_user | OpenFOAM | 23 | June 2, 2020 03:18 |
Transient simulation not converging | skabilan | OpenFOAM Running, Solving & CFD | 14 | December 17, 2019 00:12 |
Superlinear speedup in OpenFOAM 13 | msrinath80 | OpenFOAM Running, Solving & CFD | 18 | March 3, 2015 06:36 |
Time step size, number of time steps and max iterations per time step | guido_88 | FLUENT | 4 | August 30, 2012 15:49 |
