Please help!! URGENT!! Flow through diffuser
Old   March 6, 2012, 08:39
Default Please help!! URGENT!! Flow through diffuser
karthiek
karthikn21590 is on a distinguished road
I am currently modelling flow through a gas turbine diffuser. I ve used K-E model with 0.3% turbulence intensity, inlet- 37m/sec velocity, outlet- atm pressure, free slip wall, incompressible flow, fluid-air.
I am also trying to verify the results experimentally.
The problem is my pressure values are sort of alright. But the velocity values have gone haywire.
My diffuser area ratio is 0.3249. So the exit velocity should be around 10m/sec. But I get values of 3, 4 m/sec. Is there an error in my model.
The continuity equation therefore is not satisfied. But all my residuals are perfect
Any suggestions?? Thank you
karthikn21590 is offline   Reply With Quote
diffuser
Problem: Diffuser Flow sticks to wall vigges OpenFOAM Running, Solving & CFD 0 February 22, 2012 06:41
simple problem yet complex error: analysis of flow through diffuser karthikn21590 FLUENT 2 January 27, 2012 01:52
Choke flow (Urgent) Munni FLUENT 0 April 11, 2007 11:27
Swirling flow in a diffuser: K-E over SST ? Felix CFX 3 February 27, 2007 22:03
Gravity influence of flow :Urgent Suresh Balasubramanian FLUENT 3 August 6, 2003 12:06
