Vacuum Pressure at Outflow
Old   March 6, 2012, 08:32
Default Vacuum Pressure at Outflow
Leepox is on a distinguished road
Hi guys,
Basically I am injecting air in at atmospheric pressure from one end. Whilst at the other end there is a vacuum pump sucking out the air. I take it I will have to use a pressure outlet BC.
However its asking for a gauge pressure and this is boggling me because absolute = atmospheric + gauge. (thus my operating pressure is at 0 for gauge pressure)
Since i am operating below atmospheric that means gauge has to be negative but then hysys does not allow me to do that.
Or am I completely missing the point?
Leepox is offline   Reply With Quote
Old   March 6, 2012, 10:30
scipy's Avatar
Alex Pasic
scipy is on a distinguished road
Send a message via Skype™ to scipy
Why not put the operating/enviroment pressure at 0, then on the inlet define 101325 Pa and 0 at the outlet.. wouldn't that give the same result?
scipy is offline   Reply With Quote
Old   March 8, 2012, 11:15
I'm just a bit worried that by increasing the pressure I will change the air density (as it is now effectively above atmospheric pressure) when the experimental equipment is actually working at atmospheric pressure.
Old   March 8, 2012, 11:20
scipy's Avatar
Alex Pasic
If your CFD case involves compressibility then you're probably using a density based solver and that uses the ideal gas law to determine the density.. and since it's pV=mRT, it shouldn't really matter to it if you're calculating with absolute values of pressure or gauge pressure. In fact, it's always more thermodynamicaly correct to calculate with absolute pressures (at least from what I remember about thermodynamics and fluid mechanics ).
Old   March 8, 2012, 12:24
That is brilliant! I never realised this! Thank you very much
Pressure Outlet Guage pressure Mohsin FLUENT 36 April 29, 2016 18:16
Setup/monitor points of pressure and force coefficients siw CFX 3 October 22, 2010 07:07
Pressure enigma. Sara Main CFD Forum 22 July 30, 2009 05:46
Pressure outflow w/ species; mass frac. required? Myth FLUENT 2 September 30, 2006 00:08
Hydrostatic pressure in 2-phase flow modeling (CFX4.2) HB &DS CFX 0 January 9, 2000 14:19
