Getting the pressure waves in Fluent for a water hammer problem
Old   March 5, 2012, 20:39
Default Getting the pressure waves in Fluent for a water hammer problem
Petrut Teodor
teopetre is on a distinguished road
I bet there is someone throughout this forum who ever worked in simulating the water hammer phenomena, in a pipe. My questions would be:
1. If I choose water as fluid medium, how could I transform it into a compressible fluid, via an UDF, or what MACROs could I use for this.
2. How could I better visualize the subsequent pressure fluctuations.
3. Is there the need to couple with the acoustic module? If yes, is there some tutorials to provide, I would be very grateful.
4. For the case of a sudden appearing crack in the wall pipe, is this situation a bit similar to the genuine water hammer problem?
I would be very appreciative for sharing your experiences!
Thanks in advance!
teopetre is offline   Reply With Quote
Old   April 23, 2012, 14:42
navid
ndabir is on a distinguished road
Did you solved your problem? I also need to simulate water as compressible flow. Could you please explain to me how did you solved it? use any udf or special treatments?
ndabir is offline   Reply With Quote
Old   August 6, 2013, 20:24
navid
were you able to solve your problem? I need help with solving water as compressible flow. what solver did you use?
acoustic, macro, pressure, udf, water hammer
Problem with rhoSimpleFoam : exploding enthalpy and density at the walls david39 OpenFOAM Running, Solving & CFD 6 January 18, 2011 12:49
Pressure calculation problem maolongliu OpenFOAM 1 August 15, 2010 09:05
CCL, FORTRAN and water hammer pingub CFX 3 May 13, 2010 20:15
measured pressure in the discharge pipe jumps Jan Main CFD Forum 1 October 30, 2006 08:54
Hydrostatic pressure in 2-phase flow modeling (long) DS & HB Main CFD Forum 0 January 8, 2000 16:00
