Problem with velocity values - flow through diffuser
Old   March 5, 2012, 14:43
Default Please help!! URGENT!!Flow through diffuser
karthiek
karthikn21590 is on a distinguished road
I am currently modelling flow through a gas turbine diffuser. I ve used K-E model with 0.3% turbulence intensity, inlet- 37m/sec velocity, outlet- atm pressure, free slip wall, incompressible flow, fluid-air.
I am also trying to verify the results experimentally.
The problem is my pressure values are sort of alright. But the velocity values have gone haywire.
My diffuser area ratio is 0.3249. So the exit velocity should be around 10m/sec. But I get values of 3, 4 m/sec. Is there an error in my model.
The continuity equation therefore is not satisfied. But all my residuals are perfect
Any suggestions?? Thank you
karthikn21590 is offline   Reply With Quote
diffuser, velocity
Steady pipe flow mean velocity higher than inlet velocity anita OpenFOAM Running, Solving & CFD 7 September 25, 2012 06:35
Velocity profiles problem behind the elbow (3D problem) kabat73 FLUENT 8 May 9, 2010 05:26
ATTENTION! Reliability problems in CFX 5.7 Joseph CFX 14 April 20, 2010 16:45
calculating mass flow rate from exported velocity values Sasha FLUENT 0 April 6, 2009 17:07
Velocity boundary values for inviscid flow jelmer OpenFOAM Post-Processing 2 September 12, 2006 10:56
