Dynamic Mesh of Valve Leaflet and Residual
Old   February 28, 2012, 04:21
Default Dynamic Mesh of Valve Leaflet and Residual
salvatore
stone123 is on a distinguished road
Hi All,
I am trying to simulate the motion of the aortic valve leaflet by performing a 2-way FSI and coupling FLUENT with ABAQUS. The MPCCI software is used to couple both fluid and structural software.
My problem is on the continuity between time steps. Even if the displacements of leaflets are very small, I can observe a significant jump of the residual from 10-3 to 10+2 among each time step. After this jump of residuals, the pressure outlets do not follow anymore the initial guage pressures and becames negative.
I am wondering if someone else run into a similar problem or has suggestion.
Thanks in advance
stone123 is offline   Reply With Quote
Old   March 2, 2012, 11:08
stumpy is on a distinguished road
I doubt you can solve this case using the MPCCI connection to ABAQUS. For bio-medical applications you typically need tight interface coupling. Try the new System Coupling approach in version 14.0. Search for "FSI" on the ANSYS Customer Portal to see how to stabilize this type of case with System Coupling.
stumpy is offline   Reply With Quote
Old   January 18, 2013, 05:17
Marko Milasinovic
milasko is on a distinguished road
Hi stone123,
I am also trying to simulate the motion of abdominal aorta by performing 2-way transient FSI coupling between FLUENT and MECHANICAL. Can you tell me which data you are using for wall of aorta? I need Uniaxial, Biaxial and Shear Test Data.
milasko is offline   Reply With Quote
