How to display the whole result of a periodic model via one period result?
Old   February 16, 2012, 08:49
Default How to display the whole result of a periodic model via one period result?
dixylo is on a distinguished road
Hi, all
I have got the simulation result of one period of a periodic model, a impeller-like rotator. Now I want the result of the whole geometry, such as the pressure contour of the rotator wall, the force and moment exerted on the rotator, velocity contour and vectors on a certain cross section and so on.
Could anyone tell me how to expand the result of one period to the entire calculation domain. Thanks in advance, and any help would be much appreciated.
dixylo is offline   Reply With Quote
Old   February 20, 2012, 12:56
Ed heywood-Lonsdale
eheywoodlonsdale is on a distinguished road
Try using CFD-Post, and use the calculator tab on the tob right, and then function calculator. Or if you're after visuals, try using instancing transforms:
Insert
Instancing Transform
(name)
Untick "Instancing Info From Domain"
# of Copies = however many periodic sections you want
Choose axis
And then full circle
eheywoodlonsdale is offline   Reply With Quote
Old   February 23, 2012, 05:11
federvo.mala is on a distinguished road
You can do it on Fluent too.
In the results section, click to view then define and set rotational.
I can't be more specific as I don't have fluent on hand right now.
Cheers
federvo.mala is offline   Reply With Quote
LES and combustion model Margherita Cadorin CFX 0 October 29, 2008 06:24
Kato-Launder model sam Main CFD Forum 13 September 21, 2006 11:15
Why k-epislon model perform a bad result at corner Lwrence CFX 13 April 8, 2006 08:46
a problem on Partankar's periodic boundary model harry Main CFD Forum 0 June 4, 2005 08:40
Periodic boundary conditions and RSM model Bart Prast CFX 15 October 29, 2002 17:38
