February 14, 2012, 18:43 |
cm-history power coefficient in VAWT
nazareno mancinelli
Rep Power: 17 |
hi people.. i'm facing with a problem with my 2D unsteady simulation of a VAWT.
i'm having this cm-history (fig 1). it's based on the "reference values": compute from: the bc of the velocity inlet far away of the turbine area: my VAWT diameter length: my VAWT radius you can see that after a lot revolutions i have a accurate convergence for the cm. in the next figure (fig 2) you can see that every peak its like the other one, so i think the solution its converged. so, i'm not sure how to calculate the power coefficient. if i take the mean of the cm (cmm) and make: cmm*w (w = angular velocity) i have a bad results. what should i do? kinds regards! |
cm-history, power coefficient, vawt wind turbine energy |
High torque coefficient Cm for Vertical Axis Wind Turbine (VAWT) | tony00 | FLUENT | 11 | July 23, 2018 07:13 |
VAWT power graph | ArslanOZCAN | FLUENT | 0 | May 17, 2011 06:00 |
Constant velocity of the material | Sas | CFX | 15 | July 13, 2010 09:56 |
my VAWT Darreius coefficient of performance high above Betz efficiency | radix | FLUENT | 0 | August 27, 2009 01:51 |
Automotive test case | vinz | OpenFOAM Running, Solving & CFD | 98 | October 27, 2008 09:43 |
