gambit starting problem plss help......
Old   February 14, 2012, 12:58
Default gambit starting problem plss help......
preetam
preetam69 is on a distinguished road
i am trying to start my gambit 2.3.16 using exceed 9 hummingbird......
it use to run fine,but i started it after some time ..............and this problem keeps happening.........
Locating Exceed installation ...
Launching Exceed 9 ...
Starting C:\Fluent.Inc\gambit2.3.16\ntx86\gambit.exe -device open -id default_id3512 -new ...
*** Cannot connect to license server
The server (lmgrd) has not been started yet, or
the wrong port@host or license file is being used, or the
port or hostname in the license file has been changed.
Feature: gambit
Server name: latinum.uta.edu
License path: C:\Fluent.Inc\license\ntx86\..\license.dat
FLEXlm error: -15,10. System Error: 10061 "WinSock: Connection refused"
For further information, refer to the FLEXlm End User Manual,
available at "www.macrovision.com".
Feature: gambit-addon
FATAL ERROR: Could not obtain valid license authorization.
Total of 0.00 cpu second(s), 101792 maximum memory.
can some one plss hep me out on this one............
i am a real novice................plss help me out here...........
preetam69 is offline   Reply With Quote
Old   February 15, 2012, 04:42
niaz's Avatar
A_R
niaz is on a distinguished road
you have problem with your license
it seems that you install lmgrd. if you have cracked one you should not install
it. but use registered software or open source one.
niaz is offline   Reply With Quote
Fluent 6.3 / Gambit 2.3.16 / Exceed 11 problem on Win7 pdilly FLUENT 23 April 2, 2016 12:10
Gambit geometry problem cestrin FLUENT 3 July 4, 2012 02:33
Gambit Problem Size Function El Wastl ANSYS Meshing & Geometry 12 April 15, 2011 07:17
Problem importing iges file to Gambit Tassos FLUENT 0 May 7, 2008 04:28
Startup Problem in Gambit 2.2 with WindowXP Win Win Maw FLUENT 3 January 25, 2006 11:09
