February 9, 2012, 11:48 |
[Fluent] Problem in Mach Contours
Ali
Rep Power: 16 |
I have a problem in viewing Mach contours on the body (wall), everything is blue, showing very low mach number.
I am running CFD simulation at: M =1.0, and 1.5 Ansys Fluent 13 & 14 Mesh was created in Ansys Meshing and ICEM. Pressure contours are very fine on the body. Contours of Mach in the farfield region are quite good. Kindly help me, what and where is the problem? |
February 9, 2012, 12:38 |
xrs333
Rep Power: 17 |
It's obvious, you use no-slip wall boundary conditions, velocity of wall and in vicinity is zero.
February 10, 2012, 08:24 |
Ali
Rep Power: 16 |
you are right. but in previous versions of fluent like 6.3, Mach contours can be seen.
I am saying Mach number, not the velocity magnitude. Velocity magnitude will off-course be 0. |
February 12, 2012, 06:44 |
xrs333
Rep Power: 17 |
Ma = V/c
The none zero value of Mach number on wall you saw may be cell value, not node value. |
February 13, 2012, 02:21 |
Ali
Rep Power: 16 |
Thanx.
Is it possible if my first node is far from the wall (away from the boundary layer). The Mach number shown on the wall is actually the value of that cell? |
conduction problem | venkataramana | OpenFOAM | 3 | December 1, 2013 07:30 |
Problem Importing Geometry ProE to CFX | fatb0y | CFX | 3 | January 14, 2012 19:42 |
[ICEM] [FLUENT] 2D Geometry problem when exporting to Fluent - Unwanted walls | MikeTichondrius | ANSYS Meshing & Geometry | 1 | February 9, 2011 13:31 |
natural convection problem for a CHT problem | Se-Hee | CFX | 2 | June 10, 2007 06:29 |
Adiabatic and Rotating wall (Convection problem) | ParodDav | CFX | 5 | April 29, 2007 19:13 |
