simple problem yet complex error: analysis of flow through diffuser
Old   January 26, 2012, 14:59
Default simple problem yet complex error: analysis of flow through diffuser
karthiek
karthikn21590 is on a distinguished road
Hello everyone,
I am new to both CFD and this forum. I tried to simulate turbulent flow through a diffuser. It is a 3D diffuser model. I used K-Eps model with a turbulence intensity of 1%. I used an inlet velocity boundary condition (45m/s)
and an outlet pressure condition (101325 pa). The diffuser exhausts to the atmosphere. The simulation runs fine and the pressure contours are fine. But I m unable to obtain a velocity contour. The velocity over the entire length is 0. Though the legend says that the max velocity is 46m/s, it doesnt reflect on the model. Please help. I m having a tough time with this. Do atmospheric exhausts create problems generally? My professor tried the problem in Star CCM+ and everything is fine. I m experiencing this problem in Fluent
karthikn21590 is offline   Reply With Quote
Old   January 26, 2012, 15:31
David Stanbridge
swiftaircraft is on a distinguished road
Have you tried to plot the velocities on the wall of the diffuser? If so they will be zero due to the no slip condition. Have you made a plane through the centre of the model and plotted the contours on that. The other way is to select the wall and turn off "Node value" in the contour block. Then it will show the value at the cell center.
swiftaircraft is offline   Reply With Quote
Old   January 27, 2012, 01:52
karthiek
thanks a lot Swiftaircraft. I changed the wall condition to free slip and it works perfectly
diffuser
flow past abdominal aorta. Complex BC problem. ziemowitzima OpenFOAM Running, Solving & CFD 1 July 26, 2022 06:12
Domain format problem on airfoil flow simulation andrenonaka CFX 14 December 7, 2015 01:42
Problem in k-eps turbulence code in complex geometry sontukaku Main CFD Forum 2 December 28, 2010 01:44
Simple algorithm for incompresible flow Marek Dominiak Main CFD Forum 6 April 26, 2008 04:43
? Simple CFD problem Davy Main CFD Forum 0 August 21, 1998 07:19
