Multiple Material Flow Field
Old   January 22, 2012, 18:58
Default Multiple Material Flow Field
bkaan09 is on a distinguished road
Can you model solid material and gas flow simultaneously?
I need to model a body moving along a wire at various velocities. Is there any way to model a stationary body with a wire moving through the center of the body, with airflow around the body?
I need to determine if the wire (moving at the same velocity as the gas relative to the body) has a significant effect on the drag.
If Fluent can model this can somebody direct me to a tutorial or some direction to start this analysis?
Thank you for your help!
bkaan09 is offline   Reply With Quote
air flow, material, multi phase flow, solid, two phase flows
Water subcooled boiling Attesz CFX 7 January 5, 2013 04:32
Can 'shock waves' occur in viscous fluid flows? diaw Main CFD Forum 104 February 16, 2006 06:44
Creating a mesh of the flow field in GAMBIT Vidya Raja FLUENT 0 October 3, 2005 10:53
fluid flow fundas ram Main CFD Forum 5 June 17, 2000 22:31
computation about flow around a yawed cone Tylor Xie Main CFD Forum 0 June 9, 1999 08:33
