Fluent porous media
Old   January 20, 2012, 10:20
Default Fluent porous media
Horst
lostinicem is on a distinguished road
Hello community,
as described in the title I've got some problems with porous media diffuser. I try to describe as good as possible and hope for your help
My problem is to create a fluid flow in a porous diffuser; which fluid is now not really important, so I took nitrogen like in tutorial.
So firstly I created a mesh with ICEM: http://img268.imageshack.us/img268/1076/fluent12.jpg
since I'm new to this whole stuff; I think I invested the right amount of time so it should be ok ..
so after that I imported it to fluent:
1) general: I scale it and click on axis-symmetric
2) models: I choose the viscous laminar
3) materials: nitrogen, so I took all datas from tutorial
4) cell zone conditions: I choose nitrogen and click on porous zone; i take also the same inertial and viscous resistance; so I dont use power law model nor do I change the porosity ( its 1)
5) boundary conditions): inlet: I enter here the fluid velocity, since I can calculate it; outlet: I dont touch anything here
6) solution methods: all I change here is the momentum: its on second order upwind
7) monitors: at residuals I change absolute criteria to 1e-6 ( its bigger than in tutorial, I tried to work with the bigger one, but still no convergence); surface monitors: I choose outlet as surface, I also keep the settings from tutorial
8) so at the last step I initialize and compute from inlet, since the tutorial also says so.
So I tried to change and play with the settings but still no convergence, so my velocity profile looks quiet disappionting; and also since I'm new to this stuff maybe I made a stupid mistake?
Hope someone could help me and sorry for my english
lostinicem is offline   Reply With Quote
Old   January 23, 2012, 04:17
Horst
maybe some hints?
Old   January 25, 2012, 14:40
SHL
Soheil
SHL is on a distinguished road
I'm not sure, but maybe you can try to use the ANSYS meshing. Sometimes, incompatibility in mesh causes such problems. Also, you can start calculations with first order upwaind, and then after some degree of convergence, switch to first order.
Hope this works.
SHL is offline   Reply With Quote
Old   January 26, 2012, 11:35
Horst
thanks SHL,
but already found the mistake; the problem was in the boundary condition; I didnt defined it as interior.
Porous Media Simulation with CFX/Fluent Ghasem ANSYS 1 May 14, 2013 10:07
heat transfer to porous media... club68512 FLOW-3D 5 November 4, 2010 00:20
Modelling sound propagation through layered porous media nkinar Main CFD Forum 0 July 4, 2010 15:45
Discrete phase model in porous media Pradeep FLUENT 0 February 3, 2006 17:30
porous media divergence Phil FLUENT 0 March 13, 2002 07:03
