January 19, 2012, 14:08 |
Gravity in vertical pipe
Rep Power: 17 |
does someone know how to run Fluent simulation of a vertical pipe with gravity on? I don't see any difference in the flow when gravity is enabled... Many thanks |
January 20, 2012, 00:57 |
Rep Power: 17 |
Could you provide more details, like your BC's and fluid used, single or multi phase.
January 20, 2012, 03:07 |
#3 | |
If you don't have pressure BC in incompressible flow fields, including gravity doesn't change the flow field; because you can introduce new pressure variable numerically which includes the gravity term. Obviously, you can find the original pressure field by excluding the added field. Bests,
Amir |
January 20, 2012, 03:45 |
Rep Power: 14 |
If you want to see effect of hydrostatic pressure, which depends on gravity, in a pressure field try set the operating density to zero (Cell zone conditions -> Operating conditions -> Specified operating density).
January 20, 2012, 13:42 |
Rep Power: 17 |
Thank you for the suggestion to set the operating density to zero; it seems to work well now
Thank you for your replies |
January 20, 2012, 14:01 |
Real Name :)
Rep Power: 16 |
January 20, 2012, 14:04 |
Rep Power: 17 |
It is single phase; just trying to see if the "gravity" option makes a difference in the pressures in a pipe
As a next step I am contemplating to write a UDF to try and modify the gravity vector. Would someone know how to to this? |
January 20, 2012, 14:15 |
Real Name :)
Rep Power: 16 |
Are you talking about modifying the gravity vector as the simulation proceeds, or modification to be something other than -9.81 m/s^2 in the "down" direction? If you're looking at simply modifying it from -9.81, this is what you're specifying in the X, Y, and Z components of gravity when you turn it "on." Instead of -9.81 in the Z direction, if you make it -9.81 in the Y direction, gravity will now be "sideways" instead of "down" as in your previous case.
ComputerGuy |
January 20, 2012, 14:19 |
#9 |
Rep Power: 17 |
Gravity will be rigidly defined for the entire simulation, but want to make it vary with altitude
energy conservation in vertical pipe | Atit Koonsrisuk | CFX | 1 | March 30, 2005 11:41 |
My Revised "Time Vs Energy" Article For Review | Abhi | Main CFD Forum | 2 | July 9, 2002 09:08 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 09:11 |
vertical pipe flow | sanjib das sharma | CFX | 2 | July 30, 2001 06:17 |
Effects of gravity in pipe - pressure distribution | Anthony Wachs | FLUENT | 2 | July 25, 2001 07:07 |
