January 19, 2012, 00:54 |
Cyclone separator
arjun
Rep Power: 14 |
Which model i have to use for analysis of cyclone type dust collectors.
1. multiphase eulerian + DPM ? OR 2. or only DPM is sufficient.? inlet to the cyclone is flue gas from coal fired boilers. please help me. |
January 19, 2012, 03:02 |
Rick
Rep Power: 26 |
Single phase flow; after steady solution is reached enable dpm and set injection(s).
January 19, 2012, 04:22 |
arjun
Rep Power: 14 |
is DPM sufficient for analysis of cyclone. i am getting divergence error in AMG solver: pressure correction.
after 11 iterations. |
January 19, 2012, 06:15 |
DPM is sufficient for your purpose. Pressure drop predicted by DPM without 2way coupling will be less than the actual value if your particle loading is more than 10%. So you can enable 2way interaction in this case.
Regards Sabin Mathew |
how to set BC of cyclone separator outlet | Lcw | FLUENT | 5 | February 22, 2012 01:40 |
problem about DPM of cyclone separator simulation | jason | FLUENT | 4 | November 12, 2007 03:15 |
Over predicted frequency in cyclone separator | lcw | FLUENT | 0 | March 20, 2006 23:02 |
water-oil cyclone separator | Nico | FLUENT | 1 | May 24, 2005 14:58 |
cyclone separator | Vikky | Main CFD Forum | 1 | June 29, 2003 06:05 |
