January 9, 2012, 23:38 |
Convergence and Solver Selection
Rep Power: 15 |
I have created a gas distributor with high back pressure and a choked inlet distributing into a vacuum (the operating pressure is not quite zero, but very close).
Using the pressure-based solver, I have attempted to solve. The model always diverges. No matter how much I play with the under-relaxation factors, it simply won't converge. Should I be using the density solver over the pressure solver? I am aware of the relative merits of each, but don't know what to do for this situation. The flow is slow near the inlet, but definitely compressible by the exit. It seems to fall between the two solvers, but maybe one is better than the other? I should mention that the model is very complicated, as the distributor has many exits. A simpler model does converge using the pressure solver, but the real one does not. Thanks! |
January 10, 2012, 03:38 |
duri
Rep Power: 17 |
Operating pressure doesn't matter for pressure based solver, if it is zero it will take a negative value. When compressibility effects are large (discharging into vacuum) you need to move to density based solver.
January 14, 2012, 01:34 |
Lucky
Rep Power: 66 |
The density based solver is preferred over the pressure based solver, especially for compressible flows. The density based solver is more complicated and costly compared to the pressure based solver but is much more physically accurate.
The pressure based solver can still be used but requires a lot more care. If you are using the pressure based solver, did you remember to account for the viscous heating effects caused by the shear? |
January 22, 2012, 14:21 |
Rep Power: 15 |
What do you mean by this? I did turn on the energy model and did then chose low-pressure boundary slip because it is exiting into what is essentially a vacuum. Is this what you are referring to?
January 22, 2012, 14:34 |
Lucky
Rep Power: 66 |
You should be using the density solver.
If you want to use the pressure based solver, in addition to simply 'turning on energy' you need to account for viscous heating effects. |
converge, density based solver, diverge, pressure based solver, solver |
Convergence | Centurion2011 | FLUENT | 48 | June 15, 2022 00:29 |
convergence issues on steady state solver | icemaniac178 | CFX | 1 | March 30, 2011 20:11 |
Convergence of CFX field in FSI analysis | nasdak | CFX | 2 | June 29, 2009 02:17 |
Convergence Definition of Segregated Solver | Amir | FLUENT | 0 | April 18, 2006 07:21 |
Convergence with coupled implicit solver | Henrik Ström | FLUENT | 1 | October 29, 2005 04:57 |
