2D in Fluent Vs 2D in CFX
Old   January 6, 2012, 10:28
Smile 2D in Fluent Vs 2D in CFX
mohammad
mohammad is on a distinguished road
Hi everybody,
I want to know that does the method we use in CFX for a 2D in FLUENT?
I have solved a 2D model in CFX but it gives me floating point error in FLUENT....
As you may know, in CFX we just generate a mesh with two nodes in depth, and this will be our 2 D model....I know that FLUENT is able for 2D simulation...i just want to know that does the same model with 2 nodes-in-depth work in FLUENT or not...
if not, what do you think might be the cause of error in my case?
Thanks a lot
mohammad is offline   Reply With Quote
Old   January 6, 2012, 11:02
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
As you know CFX is not the 2-D solver. Therefore to run this case you should adopt any one of the following approache:
1. Use the 2-D mesh (better approach)
2. use the symmetry condition on both sides
Far is offline   Reply With Quote
Old   January 6, 2012, 11:05
mohammad
Hi Far,
Thank you for your reply. I know that about Fluent.
My question is this:" Is a 2 node-in-depth mesh valid in FLUENT?
Regards
Old   January 6, 2012, 11:10
Far
Sijal
Yes it is valid, in this case you need to apply the symmetry on both faces.
Old   January 6, 2012, 11:12
mohammad
Thanks a lot
Old   January 6, 2012, 11:30
Far
Sijal
but be careful and check solution with more nodes as well
2_d, two dimensional
Mesh and Solve Times for CFX, Fluent, CD-adapco Jade M Main CFD Forum 4 August 28, 2012 03:54
Import CFX def into Fluent eric_wang FLUENT 0 April 18, 2011 14:14
OpenFOAM vs. Fluent & CFX marco Main CFD Forum 81 March 31, 2009 15:22
Fluent Vs CFX, density and pressure Omer CFX 9 June 28, 2007 05:13
Jobs in cfd - fluent or cfx? jobman Main CFD Forum 6 July 5, 2006 16:02
