January 2, 2012, 09:13 |
calculate integral in UDF
Yu-Pei Chen
Rep Power: 15 |
Hi, everybody.
My case has a heat flux cross the wall, and it's not a constant value. The value is calculated by integrating the domain from z1 to z2, the variable in the integral is temperature (function of z), others are just some constants. I wanna calculate the integral in UDF. I have a idea by using "TRAPEZOIDAL RULE", but I don't now how to do it. Does anyone knows how to calculate integral in UDF or how to apply TRAPEZOIDAL RULE ?? thank you very much ! |
January 2, 2012, 10:22 |
Rep Power: 15 |
Hi! You have two options how to solve this problem:
1) Write your own integration method (as you proposed) 2) Link your UDF against some numerical library (e.g. GSL) and use it inside your code. If you are fine with number 1) and you don't need such robust integration routine. Here is my implementation of Gauss–Kronrod quadrature formula, which I use in my UDFs. It requires 15 function evaluation and its accuracy is comparable with trapezoidal rule when integration interval is divided into 100 parts. PHP Code:
January 3, 2012, 10:14 |
Yu-Pei Chen
Rep Power: 15 |
Thank for your reply, sixlillers.
Actually, I wanna calculate the heat flux at a cylinder wall, I need to get the temperature data near the wall so that I can calculate the temperature difference, so I have one more question : how do I get temperature data near the wall and how to use it in the UDF that you gave me to calculate the integral. thank you ! ypchen |
January 3, 2012, 17:25 |
Rep Power: 15 |
Well I thought you need compute an integral of a scalar function (one variable). Fluent can compute surface integral by demand after simulation (Results -> Reports -> Surface Integrals) or you can setup a surface monitor, which will compute your desired integral and write its value to a file after each time step and then you will have to read it from your UDF.
January 4, 2012, 08:53 |
Hi Six KIllers
Rep Power: 15 |
I have a Problem in defining udf For Spanwise Average Nussel Number Along Flow
I have the .cas, .dat, and tecplot layout in my mail. kindly give me your , so that I can mail them the entire problem. Is it Possible to Integrate in Fluent I can Plot h*X/k along z at a line along the flow on the bottom wall. But there can be a lot of lines along the breadth. I dont want to use excel. Secondly i want the contours of Nussel no on the bottom plate, which I am able to show in Fluent, But I also want to show, the number along the contour, So that i can identify which contour is for which number , how to calculate Nussel Number, and average Nussel Number In Tecplot, By Specifying Equations is also welcome |
Drag coefficient, DPM. | jorge poyatos | FLUENT | 14 | January 20, 2012 14:41 |
UDF for Heat Exchanger model | francois louw | FLUENT | 2 | July 16, 2010 03:21 |
How to calculate the mass flow rate with UDF ? | HP | FLUENT | 0 | January 10, 2005 20:38 |
DEFINE_DPM_OUTPUT macro UDF HELP | Puneet | FLUENT | 3 | November 28, 2003 11:55 |
DEFINE_GEOM UDF Problems | Pat | FLUENT | 0 | August 14, 2003 14:16 |
