December 10, 2011, 15:21 |
Teach Me! I'll Give You A Reward!
nimbus
Rep Power: 14 |
Can someone here please teach me how to create an animation from start to finish such as below link using Gambit 2.2.30 and Fluent 6.2.16?
www.youtube.com/watch?v=Ukt_798SKrA I'll give you a reward worth USD500. |
December 12, 2011, 15:42 |
Emre G
Rep Power: 15 |
sefde,
do u imply cheating without confession? oh dear. |
December 13, 2011, 04:59 |
nimbus
Rep Power: 14 |
December 16, 2011, 12:06 |
Kailash
Rep Power: 15 |
December 17, 2011, 11:32 |
http://www.4shared.com/file/jkS45nnp...der_Re200.html
use this link and download all files (mesh, case, data file) for the Reynolds number 200. For time step 0.2 solution is fully converged. Converge further the case with time step = 0.5 and 0.001 to check the effects of time step on strouhal number, lift and drag This mesh if run for turbulence Reynolds number shall give you y+ less than 1, so this file is also valid for higher Reynolds number simulations. Any body is welcome to download this file. Last edited by Far; December 17, 2011 at 12:06. |
December 20, 2011, 10:56 |
#8 | |
nimbus
Rep Power: 14 |
Thank you anyway. Tell me, are you actually can see the animation/simulation tutorial on above link? If not, why do you show me above link? Are you making people mind being lost? If someone asking for an urgent help in A, why do you show the B one? Are you trying to push me into a deep hole pit of death? "Nimbus, this would help you" Sure buddy! Ha ha ha You treat me like a child. Now, if you really such as that wise and helpful, why not you try to tell me on how to create a full simulation/animation tutorial on flow over cylinder using gambit and fluent in your own version without having to show somebody tutorial? |
January 18, 2012, 12:43 |
#9 |
Above link is not working now. the valid link is http://www.4shared.com/rar/UCPnT5xl/cylinder_Re200.html
January 19, 2012, 00:23 |
#10 | |
Mahindra
Rep Power: 13 |
January 19, 2012, 01:28 |
#11 |
This is Fluent 13 case file so cannot be opened in older versions. You can again write the mesh file from the tin and blocking files for ICEM CFD. I shall also upload the .msh file for the users who are using older versions.
January 19, 2012, 09:44 |
#12 |
files are attached even with better topology than the previous one along with file in .msh format. Enjoy.
http://www.4shared.com/rar/VJDth73H/...00_better.html |
January 19, 2012, 22:08 |
#13 | |
Mahindra
Rep Power: 13 |
January 20, 2012, 13:01 |
#14 | |
Boundary conditions are Velocity = 1 m/s L = 1 m , density = 1 kg/m3 and viscosity calculated from Reynolds number formula. Total no. of nodes = 44468 |
January 21, 2012, 06:44 |
#15 |
There is minor error in uploaded files (wall in interior). New files are here http://www.4shared.com/rar/R7dSz2kw/...21_2012_2.html
January 22, 2012, 00:31 |
#16 | |
shoeb khan
Rep Power: 14 |
fluent 14 or 13 calculation activities>> solution animations>>create edit>> active sequence = 1 define then go to countor or pathlies and whatever you want to create the animation and make it run when your simulation is complete go to graphics animation>>scene animation read t he file >>write it iin mpeg file and you are done thanks and regards SHK |
June 17, 2016, 12:49 |
#17 | |
Vasilis
Rep Power: 10 |
Can anyone give me some hint on how to make traction free boundary condition? | poplar | OpenFOAM | 3 | January 14, 2015 02:37 |
can any body give me an answer about the notice | wwwuxing | Main CFD Forum | 2 | December 25, 2010 22:55 |
How to give volume fraction in multiphase models | chhanwal | FLUENT | 0 | August 13, 2009 00:07 |
How to give mass flow inlet boundary condition | kiran | Siemens | 2 | July 5, 2007 22:43 |
Help! how to give initial VOF | Ray | Main CFD Forum | 3 | November 11, 1999 10:13 |
