December 10, 2011, 02:43 |
Inlet velocity mismatch in low microchannel
deewakar
Rep Power: 15 |
Hello everyone,
I am trying to simulate flow in rectangular micro channel of dimension (10 X 10 um). I gave the inlet velocity as its criteria and applied uniform flux on its wall. However I am facing some issues reg. that. [my flow is along 'z' direction, width along 'x' and height along 'y'] Firstly, I applied a uniform velocity 10m/s at the inlet. But when I tried to plot it velocity vs height at the inlet, fluent showed correct velocity plrofile for y up-to 9.5 micron.However, for 9.5 micron to 10 micron height there was linear variation.(where as as expected it should have been 10 through out,as inlet velocity is constant at 10). Is it that fluent is not fit for such small dimension. ?? Or is it that it has included contraction effects etc. If so , how to do away with them. Similarly there was problem with flux applied.I applied 50,000 W/m2. But it was showing 1.2e6 (considerably more than what I applied) in small region after which it showed normal expected behavior. Pls guide. thanks |
Steady pipe flow mean velocity higher than inlet velocity | anita | OpenFOAM Running, Solving & CFD | 7 | September 25, 2012 06:35 |
FSI- Pipe- uniform velocity profile inlet | Absy | Main CFD Forum | 0 | April 6, 2010 04:01 |
inlet velocity BC | ahsan | FLUENT | 3 | July 22, 2009 05:17 |
Pressure Inlet Velocity | prapanj | OpenFOAM | 11 | June 23, 2009 12:15 |
Variables Definition in CFX Solver 5.6 | R P | CFX | 2 | October 26, 2004 03:13 |
