Problem in interfacing
Old   December 9, 2011, 06:55
Default Problem in interfacing
Vaibhav Rai Khare
vaibhavraikhare is on a distinguished road
i have prepared a model in Gambit n applied interface command on it..after exporting in fluent i did grid interfacing of the interface..but heat transfer is not passing the interface..the upper side of model is being unaffected..is there any other process which i left during processing or initialization????
vaibhavraikhare is offline   Reply With Quote
Old   December 9, 2011, 07:50
Amir's Avatar
Amir
Amir is on a distinguished road
I'm not sure; but I think you have to set interface type to "coupled" in "define->grid interface".
Bests,
Amir
Amir is offline   Reply With Quote
Old   December 9, 2011, 08:01
Vaibhav Rai Khare
Thnkx amir, but i have already done that but there is no change on upper side of interface.
Old   December 10, 2011, 02:28
deewakar
alligngr8 is on a distinguished road
hi,
What I perceive from your statement is that you have 2 regions say a solid and liquid and you want to study the temperature etc profile in them.But the way you are proceeding , u are getting profiles independent of each other.I n short you want to carry out conjugate heat transfer analysis.
If that is the case do the following:
when you are making geometry, select the parts (or zones , fluid and solid to be studied in ur case )and convert them in to one body by selecting make new part.
after that when u mesh and all it will show the desired results.
alligngr8 is offline   Reply With Quote
UDF compiling problem Wouter Fluent UDF and Scheme Programming 6 June 6, 2012 05:43
Gambit - meshing over airfoil wrapping (?) problem JFDC FLUENT 1 July 11, 2011 06:59
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 07:29
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 20:13
Is this problem well posed? Thomas P. Abraham Main CFD Forum 5 September 8, 1999 15:52
