Bad Cd results applying k-ε models to hydrofoil
Old   December 9, 2011, 06:17
Default Bad Cd results applying k-ε models to hydrofoil
spk
spk is on a distinguished road
Hi guys,
I simulated a 2D hydrofoil geometry in non-cavitating conditions.
The tested angles are from 0 to 10 degrees and the velocity is constant.
I simulated this hydrofoil using Spalart-Allmaras, k-ε models and k-ω models. Using S-A and k-ω models i have good results for Cl and Cd comparing with experimental results.
But using the k-ε models (standard,rng,realizable) i have good results for Cl but bad results for Cd (as the angle attack increases Cd decreases!)
Also i used enhanced wall treatment (y+=1).
k-ε models cant solve correctly the drag coefficient in hydrofoils?
Please could you help me?
spk
spk is offline   Reply With Quote
Old   December 10, 2011, 09:27
spk
The problem is solved!
bad results when compared with other simulations Le Stanc CFX 12 November 8, 2006 02:47
Bad results when compared with Wind Tunnel Luiz CFX 7 October 27, 2006 10:35
applying results as b.c on some other model manohar FLUENT 3 October 10, 2005 08:03
Comparing Results between Models Mark CFX 2 July 26, 2004 19:29
comparing different models and grids Philipp Main CFD Forum 4 August 31, 2001 05:14
